Hi everyone
After I read a lot of posts and I coudn't find what to do.
My car is :
E 240 T ( S 210 ) ( 2000 )
2.4 L , 6 V, petrol
Country : Norway
I bought it before one month and was working perfect, I used petrol from used car garage , before 10 days the problem start when I try to start on the car but its cranking without firing , so after many try it work and I drove it just fine , after 2 days the problem become bigger so the car stop when I reduce the speed for exp : when I am in round a bout the engine dead and all the lights are on , and after many many times with trying to start it a gain then its start,
I checked it with the normal scan and the error code are 2 :
1 - Crank shaft sensor
2 - Cam shaft sensor
and the light engine was on.
then I changed the Cam shaft sensor from second hand parts and the engine light turned off.
and I change the Crank shaft sensor from second hand also put the problem still there and I notice when the temp. reach to 80 the car engine dead ( the car stop ) , and I tried to turn it on but its cranking and not firing , then I wait until the temp. go down and then try to switch it on and the car cranking and firing , also I changed the K40 relay from second hand and the problem is same.
the man who scan it has been traveled .
its costly to take the car to the dealer or to one of the workshop here its too expensive here .
Please any one who has same issue or has experience can help me or tell me what to do ?
Best Regards
My car is :
2.4 L , 6 V, petrol
Country : Norway
Best Regards
