specialshoe
- Aug 23, 2009
Hi all
bit of brain picking if I may
2000 V6 petrol E240 - fault codes showing are P2064 and P2004.
I think the 2004 is 'intake manifold runner stuck open' and 2064 is 'reductant supply control circuit high'.
Firstly does anybody know if these codes are right - all the charts seem to suggest correct.
More importantly I think the 'inlet manifold' thing is a flap operated by a small motor in the intake manifold - where is it, can it be got at reasonably easily - and is it worth having a poke at it with wd40 etc to make it live again?
I am guessing the 2064 code is a result of the 2004 as it is a monitoring circuit - or have I guessed this wrongly?
The symptoms are - car drives fine if up to about half throttle is used - boot it and it coughs and cuts out until throttle is backed off, idle speed about 700rpm not the usual 500, fuel consumption about normal.
Probably time I bought a workshop manual - are there any half decent ones that don't just say ' get a bigger hammer' ?
Many thanks in advance for any help forthcoming....
