- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
For some time I've had a bit of an exhaust rattle from beneath the E300TD saloon.
Though it was one of those heat shields .... But Not-so.
Back from the particulate filter, there's a hanger bracket.
The two bolts in this had worked very-loose ... finger tight ... Hence the rattle.
I pinched them up.
The rattle stopped.
BUT
Given that the hanger bracket is fixed to the floor of the car and is not a rubber mount means that any movement of the engine on its mounts could strain the exhaust against this fixing point.
Is it wise to pinch these bolts up tight.
OR
Is a little bit of "give" at this point desirable ?
I could achieve this by tightening sufficient to remove the rattle, and then lock-nutting the fasteners.
Any thoughts welcome.
I pinched them up.
The rattle stopped.
BUT
OR
