PaulW said:So, is there really any difference in fuel usage between the two ?
Brian WH said:We have had this discussion before, try a search on Winter or Summer settings here.
"Economy" is the same as the modern "Winter" setting, which takes off in second and changes later. Supposed to give better Mpg but I am not convinced.
My C200 has a E-S switch. When I queried a fault at my local independant I was told the switch makes little difference i.e. it marginally affects the gear change points. Also the w-s switch was on a different gearbox and its operation had a greater effect e.g. staring in 2nd. The e-s switch was referred to as a 'bull**** switch.'PaulW said:Being new to MB's I am not sure whether I should be driving in the standard or economy setting on the auto box can someone enlighten me please
I normally use economy on the motorways.
