Andrew Mills
- Aug 23, 2014
Occasionally get an error message telling me to reduce the level of engine oil. It says on for a couple of seconds and goes away and doesn't register as a malfunction on the centre display. It has one of those electronic sensors and no dipstick
I run a E 320 CDI with nearly 70k on the clock.
I have checked the inside of the filler cap and no signs of water, radiator expansion tank has no oil in it so I am assuming the head gasket is ok.
Does anyone know if this is just a sensor issue or is it something more serious
Any comments gratefully received
Andrew
Andrew
