engine transplant???
ohlord
GLASGOW
1999,e320 cdi,auto
would it be possible to fit an c class 220 cdi to an e class 320 cdi? would it be a simple straight swap or would the gearbox require changing? ecu problems,etc?
Sorry i can`t help,but why?
have trouble with "worn crankshaft" at crankshaft pulley. looking for cost effective solution.dont know what to do.any ideas most welcome.
car drives great but minor oil leak,had oil seal done 5 weeks ago.
Start getting quotes for a quality used motor that WILL fit your car and get quotes for the repair from reputable garages for the repair of the original. Pick the cheaper of the two?
Fix your one is the way to go as at least you know the story,but if you get a secong hand one things might go wrong before you know it
Fit a used 320cdi unit. There are loads about. The 220cdi transplant would not be worth it financially.
hi
sell the car and get a 220cdi
acid
Buy a new genuine front crank seal then go to a bearing factor and get one with a smaller internal diameter, only by a knatts tadger but maybe worth a go.
You cant write of a whole engine because of a seal.
Lynall
lynall,only post worthy of mention,more details please?? thanks.
Thats certainly the way to obtain more friendly help from the forum regulars.........
Then again, we're only here to serve you, aren't we?
I thought there was some sensible helpful options posted.:dk:
And you want to stick a 220 C engine, in a 320 E, yeh you go for it mate.:wallbash:
Go Swing then fella, Don't go onto a forum and ask for advice then when people suggest THE PROPER way of repairing your car giving the information YOU provided, then crapping on other peoples advice because you haven't done your research or had the fault investigated properly by someone who knows what they are doing... We should have let you buy an unsuitable engine.
Your on your own mate, have a nice Christmas...
Yeah Lynall stop posting unworthy advice to people trying to bodge their cars please. My worthy advice is to fit a Renault 21 diesel engine, it goes straight in as far as i know and should run like a dream......:rolleyes:
He could put some sawdust in the oil filler - that might stop the leak .
Other 'additives' : treacle ? , Tar ?
What else ???
What else ???
Im pretty sure that sugar in the fuel tank will plug the leak and fix it all up good as new.....
