para alpha
Noticed it this morning, The mileage readout is very faint anyone have any idea what's wrong and how to fix it?
I have just ordered the hook pullers this afternoon. So as soon as they turn up I'll pull out the cluster. It's a good time to do it as I need to replace the indicator stalk, the intermittent screen wipe has long since died. I have a spare one so that job will be quick. it is recommended to crack the cap on the steering column with the steering lock on? I know on some cars if you do that it snaps the steering lock?I'm not sure if ita bulb that needs repalcing - most likely culprit would be a "dry" connection that hasnt established full contact. You may have to get the cluster out and physically push all connectors home to make sure they're all in. another possibility is an earth leakage if one of the ribbons has abraded and is earthing somewhere
