Charles Morgan
- Feb 2, 2010
- Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
My BMW M535i has 4 seat shocks fitted - two for height and two for backrest angle. All are a bit past it, the result being that if you try to adjust backrest angle the seat will simply collapse to horizontal. Not helpful on the move.
I bought some replacements, and managed to fit the first height adjustment one today. This was an utter pig, as the shock is un-compressed prior to fitting and it is 350nm to compress it. Each of the holes slots into a stud on the seat base. I was able to do it using my bench vice, but that meant moving the seat around on the work bench. Took 3 hours of fiddling and cursing, and that is the easy one.
The rear back rest one is horribly more tight to fit. Any ideas on a portable tool of limited size that might be usable to compress this one for easier fitting? It's about 15 cm long and would need to compress about 5 cm to fit the studs.
