The Mirror Man
- Jan 29, 2015
- W211 E270 CDI Elegance.Rover 75 Tourer
front lower control arm , diy job certainly . 610220995 ecp . or try car parts 4 less. lemforder ...
Will MB really sell you the front wheel bearings? I thought you could only buy the complete hub from them for about £190 which has the bearings and grease already in. I just bought SKF bearings from ECP for about £35 but would have got genuine MB parts had I known they were available.
good luck doing them bearings .
not at all . if you get the racers out and new bearings in , the rear seal is also the abs , power steering , and esp pick up sensor . i used lucas parts and it turned sour , maybe you'll have better luck .
guide here ---- https://www.youtube.com/watch?v=j_Pu5BNUX5I
have you got the part numbers for the bearing kit mb supplied ??
Are the racers on that list ?
