E270 Owner
Anyone familiar with this fault ?
Low pressure test is fine engine cuts out on high pressure test
Pressure sensor test is ok and the valve control tests ok in DAS
Various fault codes
DAS >
2047-001 Rail pressure to low volume control valve
2015-001 Rail pressure to low volume control valve
2051-001 Rail pressure to low pressure control valve
2019-001 Rail pressure to low pressure control valve
EOBD II >
P2056 Injection pump fuel metering control B malfunction (cam/rotor/injector)
P2051 Injection pump fuel metering control A malfunction (cam/rotor/injector)
I'm wondering if there's a faulty injector causing the problem.
Various fault codes
DAS >
EOBD II >
