ChrisA
- Aug 18, 2013
- Location
- East Riding/Germany/Denmark
- CL 63 Biturbo 2014 - S63L 2010 - CLS Weistec MSL Monster (RIP)
OBD II Fault Codes Reference Guide
The Diagnostic Trouble Code numbering follows a standardized structure. All Diagnostic Trouble
Codes have a letter followed by a 4-digit number (e.g. P1234). The first letter indicates the type of
code:
P = Powertrain
C = Chassis
B = Body
U = Network Communication
The remaining 4-digit number specifies the problem within that system.
P00XX Fuel and Air Metering and Auxiliary Emission Controls
P0010 “A” Camshaft Position Actuator Circuit (Bank 1)
P0011 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0012 “A” Camshaft Position - Timing Over-Retarded (Bank 1)
P0013 “B” Camshaft Position - Actuator Circuit (Bank 1)
P0014 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0015 “B” Camshaft Position -Timing Over-Retarded (Bank 1)
P0020 “A” Camshaft Position Actuator Circuit (Bank 2)
P0021 “A” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0022 “A” Camshaft Position - Timing Over-Retarded (Bank 2)
P0023 “B” Camshaft Position - Actuator Circuit (Bank 2)
P0024 “B” Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
P0025 “B” Camshaft Position - Timing Over-Retarded (Bank 2)
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
P0033 Turbo Charger Bypass Valve Control Circuit
P0034 Turbo Charger Bypass Valve Control Circuit Low
P0035 Turbo Charger Bypass Valve Control Circuit High
P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
P0065 Air Assisted Injector Control Range/Performance
P0066 Air Assisted Injector Control Circuit or Circuit Low
OBD 2 Fault Codes Reference Guide
P0067 Air Assisted Injector Control Circuit High
P0070 Ambient Air Temperature Sensor Circuit
P0071 Ambient Air Temperature Sensor Range/Performance
P0072 Ambient Air Temperature Sensor Circuit Low Input
P0073 Ambient Air Temperature Sensor Circuit High Input
P0074 Ambient Air Temperature Sensor Circuit Intermittent
P0075 Intake Valve Control Solenoid Circuit (Bank 1)
P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
P0081 Intake valve Control Solenoid Circuit (Bank 2)
P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
P01XX Fuel and Air Metering
P0100 Mass or Volume Air Flow Circuit
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0104 Mass or Volume Air Flow Circuit Intermittent
P0105 Manifold Absolute Pressure/Barometric Pressure Circuit
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110 Intake Air Temperature Circuit
P0111 Intake Air Temperature Circuit Range/Performance Problem
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature Circuit
P0116 Engine Coolant Temperature Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle/Pedal Position Sensor/Switch A Circuit
P0121 Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem
P0122 Throttle/Pedal Position Sensor/Switch A Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch A Circuit High Input
P0124 Throttle/Pedal Position Sensor/Switch A Circuit Intermittent
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Stable Operation
P0127 Intake Air Temperature Too High
P0128 Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature)
P0130 O2 Sensor Circuit (Bank 1 Sensor 1)
P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit (Bank 1 Sensor 1)
P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit (Bank 1 Sensor 2)
P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147 O2 Sensor Heater Circuit (Bank 1 Sensor 3)
P0148 Fuel Delivery Error
P0149 Fuel Timing Error
P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit (Bank 2 Sensor 1)
P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 O2 Sensor Heater Circuit (Bank 2 Sensor 2)
P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 O2 Sensor Heater Circuit (Bank 2 Sensor 3)
P0168 Fuel Temperature Too High
P0169 Incorrect Fuel Composition
P0170 Fuel Trim (Bank 1)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
P0174 System too Lean (Bank 2)
P0175 System too Rich (Bank 2)
P0176 Fuel Composition Sensor Circuit
P0177 Fuel Composition Sensor Circuit Range/Performance
P0178 Fuel Composition Sensor Circuit Low Input
P0179 Fuel Composition Sensor Circuit High Input
P0180 Fuel Temperature Sensor A Circuit
P0181 Fuel Temperature Sensor A Circuit Range/Performance
P0182 Fuel Temperature Sensor A Circuit Low Input
P0183 Fuel Temperature Sensor A Circuit High Input
P0184 Fuel Temperature Sensor A Circuit Intermittent
P0185 Fuel Temperature Sensor B Circuit
P0186 Fuel Temperature Sensor B Circuit Range/Performance
P0187 Fuel Temperature Sensor B Circuit Low Input
P0188 Fuel Temperature Sensor B Circuit High Input
P0189 Fuel Temperature Sensor B Circuit Intermittent
P0190 Fuel Rail Pressure Sensor Circuit
P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
P0192 Fuel Rail Pressure Sensor Circuit Low In put
P0193 Fuel Rail Pressure Sensor Circuit High Input
P0194 Fuel Rail Pressure Sensor Circuit Intermittent
P0195 Engine Oil Temperature Sensor
P0196 Engine Oil Temperature Sensor Range/Performance
P0197 Engine Oil Temperature Sensor Low
P0198 Engine Oil Temperature Sensor High
P0199 Engine Oil Temperature Sensor Intermittent
P02XX Fuel and Air Metering
P0200 Injector Circuit
P0201 Injector Circuit - Cylinder 1
P0202 Injector Circuit - Cylinder 2
P0203 Injector Circuit - Cylinder 3
P0204 Injector Circuit - Cylinder 4
P0205 Injector Circuit - Cylinder 5
P0206 Injector Circuit - Cylinder 6
P0207 Injector Circuit - Cylinder 7
P0208 Injector Circuit - Cylinder 8
P0209 Injector Circuit - Cylinder 9
P0210 Injector Circuit - Cylinder 10
P0211 Injector Circuit - Cylinder 11
P0212 Injector Circuit - Cylinder 12
P0213 Cold Start Injector 1
P0214 Cold Start Injector 2
P0215 Engine Shutoff Solenoid
P0216 Injector/Injection Timing Control Circuit
P0217 Engine Coolant Over Temperature Condition
P0218 Transmission Fluid Over Temperature Condition
P0219 Engine Over Speed Condition
P0220 Throttle/Pedal Position Sensor/Switch “B” Circuit
P0221 Throttle/Pedal Position Sensor/Switch “B” Circuit Range/Performance Problem
P0222 Throttle/Pedal Position Sensor/Switch “B” Circuit Low Input
P0223 Throttle/Pedal Position Sensor/Switch “B” Circuit High Input
P0224 Throttle/Pedal Position Sensor/Switch “B” Circuit Intermittent
P0225 Throttle/Pedal Position Sensor/Switch “C” Circuit
P0226 Throttle/Pedal Position Sensor/Switch “C” Circuit Range/Performance Problem
P0227 Throttle/Pedal Position Sensor/Switch “C” Circuit Low Input
P0228 Throttle/Pedal Position Sensor/Switch “C” Circuit High Input
P0229 Throttle/Pedal Position Sensor/Switch “C” Circuit Intermittent
P0230 Fuel Pump Primary Circuit
P0231 Fuel Pump Secondary Circuit Low
P0232 Fuel Pump Secondary Circuit High
P0233 Fuel Pump Secondary Circuit Intermittent
P0234 Turbo/Super Charger Overboost Condition
P0235 Turbo/Super Charger Boost Sensor “A” Circuit
P0236 Turbo/Super Charger Boost Sensor “A” Circuit Range/Performance
P0237 Turbo/Super Charger Boost Sensor “A” Circuit Low
P0238 Turbo/Super Charger Boost Sensor “A” Circuit High
P0239 Turbo/Super Charger Boost Sensor “B” Circuit
P0240 Turbo/Super Charger Boost Sensor “B” Circuit Range/Performance
P0241 Turbo/Super Charger Boost Sensor “B” Circuit Low
P0242 Turbo/Super Charger Boost Sensor “B” Circuit High
P0243 Turbo/Super Charger Wastegate Solenoid “A”
P0244 Turbo/Super Charger Wastegate Solenoid “A” Range/Performance
P0245 Turbo/Super Charger Wastegate Solenoid “A” Low
P0246 Turbo/Super Charger Wastegate Solenoid “A” High
P0247 Turbo/Super Charger Wastegate Solenoid “B”
P0248 Turbo/Super Charger Wastegate Solenoid “B” Range/Performance
P0249 Turbo/Super Charger Wastegate Solenoid “B” Low
P0250 Turbo/Super Charger Wastegate Solenoid “B” High
P0251 Injection Pump Fuel Metering Control “A” (Cam/rotor/Injector)
P0252 Injection Pump Fuel Metering Control “A” Range/Performance (Cam/Rotor/Injector)
P0253 Injection Pump Fuel Metering Control “A” Low (Cam/Rotor/Injector)
P0254 Injection Pump Fuel Metering Control “A” High (Cam/Rotor/Injector)
P0255 Injection Pump Fuel Metering Control “A” Intermittent (Cam/Rotor/Injector)
P0256 Injection Pump Fuel Metering Control “B” (Cam/Rotor/Injector)
P0257 Injection Pump Fuel Metering Control “B” Range/Performance (Cam/Rotor/Injector)
P0258 Injection Pump Fuel Metering Control “B” Low (Cam/Rotor/Injector)
P0259 Injection Pump Fuel Metering Control “B” High (Cam/Rotor/Injector)
P0260 Injection Pump Fuel Metering Control “B” Intermittent (Cam/Rotor/Injector)
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0263 Cylinder 1 Contribution/Balance
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0266 Cylinder 2 Contribution/Balance
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0269 Cylinder 4 Contribution/Balance
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0272 Cylinder 4 Contribution/Balance
P0273 Cylinder 5 Injector Circuit Low
P0274 Cylinder 5 Injector Circuit High
P0275 Cylinder 5 Contribution/Balance
P0276 Cylinder 6Injector Circuit Low
P0277 Cylinder 6 Injector Circuit High
P0278 Cylinder 6 Contribution/Balance
P0279 Cylinder 7 Injector Circuit Low
P0280 Cylinder 7 Injector Circuit High
P0281 Cylinder 7 Contribution/Balance
P0282 Cylinder 8 Injector Circuit Low
P0283 Cylinder 8 Injector Circuit High
P0284 Cylinder 8 Contribution/Balance
P0285 Cylinder 9 Injector Circuit Low
P0286 Cylinder 9 Injector Circuit High
P0287 Cylinder 9 Contribution/Balance
P0288 Cylinder 10 Injector Circuit Low
P0289 Cylinder 10 Injector Circuit High
P0290 Cylinder 10 Contribution/Balance
P0291 Cylinder 11 Injector Circuit Low
P0292 Cylinder 11 Injector Circuit High
P0293 Cylinder 11 Contribution/Balance
P0294 Cylinder 12 Injector Circuit Low
P0295 Cylinder 12 Injector Circuit High
P0296 Cylinder 12 Contribution/Balance
P0298 Engine Oil Over Temperature
P03XX Ignition System or Misfire
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
P0305 Cylinder 5 Misfire Detected
P0306 Cylinder 6 Misfire Detected
P0307 Cylinder 7 Misfire Detected
P0308 Cylinder 8 Misfire Detected
P0309 Cylinder 9 Misfire Detected
P0310 Cylinder 10 Misfire Detected
P0311 Cylinder 11 Misfire Detected
P0312 Cylinder 12 Misfire Detected
P0313 Misfire Detected with Low Fuel
P0314 Single Cylinder Misfire (Cylinder not Specified)
P0320 Ignition/Distributor Engine Speed Input Circuit
P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
P0324 Knock Control System Error
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor)
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329 Knock Sensor 1 Circuit Input Intermittent (Bank 1 or Single Sensor)
P0330 Knock Sensor 2 Circuit (Bank 2)
P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
P0333 Knock Sensor 2 Circuit High Input (Bank 2)
P0334 Knock Sensor 2 Circuit Input Intermittent (Bank 2)
P0335 Crankshaft Position Sensor A Circuit
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0337 Crankshaft Position Sensor A Circuit Low Input
P0338 Crankshaft Position Sensor A Circuit High Input
P0339 Crankshaft Position Sensor A Circuit Intermittent
P0340 Camshaft Position Sensor “A” Circuit (Bank 1 or Single Sensor)
P0341 Camshaft Position Sensor “A” Circuit Range/Performance (Bank 1 or Single Sensor)
P0342 Camshaft Position Sensor “A” Circuit Low Input (Bank 1 or Single Sensor)
P0343 Camshaft Position Sensor “A” Circuit High Input (Bank 1 or Single Sensor)
P0344 Camshaft Position Sensor “A” Circuit Intermittent (Bank 1 or Single Sensor)
P0345 Camshaft Position Sensor “A” Circuit (Bank 2)
P0348 Camshaft Position Sensor “A” Circuit Range/Performance (Bank 2)
P0347 Camshaft Position Sensor “A” Circuit Low Input (Bank 2)
P0348 Camshaft Position Sensor “A” Circuit High Input (Bank 2)
P0349 Camshaft Position Sensor “A” Circuit Intermittent (Bank 2)
P0350 Ignition Coil Primary/Secondary Circuit
P0351 Ignition Coil “A” Primary/Secondary Circuit
P0352 Ignition Coil “B” Primary/Secondary Circuit
P0353 Ignition Coil “C” Primary/Secondary Circuit
P0354 Ignition Coil “D” Primary/Secondary Circuit
P0355 Ignition Coil “F” Primary/Secondary Circuit
P0356 Ignition Coil “F” Primary/Secondary Circuit
P0357 Ignition Coil “G” Primary/Secondary Circuit
P0358 Ignition Coil “H” Primary/Secondary Circuit
P0359 Ignition Coil “I” Primary/Secondary Circuit
P0360 Ignition Coil “J” Primary/Secondary Circuit
P0361 Ignition Coil “K Primary/Secondary Circuit
P0362 Ignition Coil “L’ Primary/Secondary Circuit
P0365 Camshaft Position Sensor “B” Circuit (Bank 1)
P0366 Camshaft Position Sensor “B” Circuit Range/Performance (Bank 1)
P0367 Camshaft Position Sensor “B” Circuit Low Input (Bank 1)
P0368 Camshaft Position Sensor “B” Circuit High Input (Bank 1)
P0369 Camshaft Position Sensor “B” Circuit Intermittent (Bank 1)
P0370 Timing Reference High Resolution Signal “A”
P0371 Timing Reference High Resolution Signal “A” Too Many Pulses
P0372 Timing Reference High Resolution Signal “A” Too Few Pulses
P0373 Timing Reference High Resolution Signal “A” Intermittent/Erratic Pulses
P0374 Timing Reference High Resolution Signal “A” No Pulse
P0375 Timing Reference High Resolution Signal “B”
P0376 Timing Reference High Resolution Signal “B” Too Many Pulses
P0377 Timing Reference High Resolution Signal “B” Too Few Pulses
P0378 Timing Reference High Resolution Signal “B” Intermittent/Erratic Pulses
P0379 Timing Reference High Resolution Signal “B” No Pulses
P0380 Glow Plug/Heater Circuit “A”
P0381 Glow Plug/Heater Indicator Circuit
P0382 Glow Plug/Heater Circuit “B”
P0385 Crankshaft Position Sensor “B” Circuit
P0386 Crankshaft Position Sensor “B” Circuit Range/Performance
P0387 Crankshaft Position Sensor “B” Circuit Low Input
P0388 Crankshaft Position Sensor “B” Circuit High Input
P0389 Crankshaft Position Sensor “B” Circuit Intermittent
P0390 Camshaft Position Sensor “B” Circuit
P0391 Camshaft Position Sensor “B” circuit Range/Performance (Bank 2)
P0392 Camshaft Position Sensor “B” Circuit Low Input (Bank 2)
P0393 Camshaft Position Sensor “B” Circuit High Input (Bank 2)
P0394 Camshaft Position Sensor “B” Circuit Intermittent (Bank 2)
code:
P = Powertrain
C = Chassis
B = Body
