dieselc220
Hi I've just purchased my first Mercedes which is a 2005 c220cdi, there is no history of automatic gearbox fluid change, is it worth getting done ? She has done 100000 miles. Any advice would be helpful.
And by someone who knows how to do it properly!
tromppost said:I thought it was just "suck" out the oil change filter odd washer little gasket thing and then refill ? Alway wonder how much old oil get left behind....
I'm in the same position. Just bought a Merc with 722.6 gearbox with just over 80000 miles. No evidence of it having had a gearbox fluid change in the service history so I'm assuming the fluid is the original factory fill.
Should I change the fluid? I've heard advice that once past a highish mileage its best to leave it until it fails as the gearbox can be "shocked" by having new fluid put in it leading to premature failure. Is this a myth?
Just had mine changed by cowdray car centre in Colchester, can't believe the difference it has made to the gear changes so I would say IF IN DOUBT GET IT DONE!!!!dieselc220 said:Hi I've just purchased my first Mercedes which is a 2005 c220cdi, there is no history of automatic gearbox fluid change, is it worth getting done ? She has done 100000 miles. Any advice would be helpful.
I know some models were supplied with so called sealed for life gearboxes that never needed fluid changes. Opinions vary but, put it this way, they don't do it now. All boxes have scheduled fluid changes !
Hi I am near Colchester is the cowdray a Mercedes garage? And could I ask you what it cost please thanksJust had mine changed by cowdray car centre in Colchester, can't believe the difference it has made to the gear changes so I would say IF IN DOUBT GET IT DONE!!!!
What benefit is there from resetting the ECU as described above??
Got my C200 booked in for a gearbox oil service at the end of the month and now wondering if I should do this when it comes back?
