Gear Box oil Dipstick
EasyManHugo
Telford
W124 coupe 320 coupe, XLWB Vito V6, C220 diesel estate
Hi there
1999 sl320 v6
722.607 transmission
Made it home in limp mode. Think that a transmission oil cooler pipe has a leak.
Bought an Ebay gear box oil dipstick. Doesen't insert to it's full length. Is this correct?
Also...can you change the gearbox electro plate without connecting to the car to a computer?
Many Thanks
EMH
The dipsticks dont go all the way in as they are not meant to be left in situ, they are only meant to take a measurement reading ( when engine is at operating temperature)
Dont know about the conductor plate
Is it a 722.6 5 speed gearbox?
You can change the gearbox conductor plate without STAR, but ensure the oil temperature is correct when taking measurements.
The only problem I see is you will need some sort of diagnostics to clear any faults stored.
What are your symptoms/codes?
it doesn't insert to its full length as its a tool not a dipstick. as its meant for different cars with different tube lengths etc so there is always about 30cm spare.
