giving a w202 longer legs
RICHIS
c250 td
hi there got a w reg c250td manuel saloon currently running a little bit more than stock power with upped fueling is there a diff off another model w202 auto maybe or estate ? or a diffrent model altogether that will up my gear for more speed per gear ? and will swap straight over
cheers
The diffs from the w124, w201, w202, are interchangable.
Do you know what ratio you have now?
i think the manuels are 3.46 but havent checked mine personaly
Where abouts are you?
gloucestershire
I've got a good 3.07 diff here, depending on what your ratio is, would you be intrested in a swap?
