Hi All,
I have a set of H&R hubcentric 20mm Spacers for sale. Trak+ DRA series. Bolt pattern 5/112 - Center Bore 66.5 - DRA 40556654
Can be used for rears or fronts.
Please check H&R website for fitment.
http://www.trakplus.com/application
£50 for the pair. Can be collected from Hampshire/Portsmouth region.
Can also collect from PCS Horndean.
Postage extra.
DRA Series spacers bolt to the hub with special wheel bolts (included) and provide new threaded holes for the existing wheel bolts.
No need to longer wheel studs. Use back original wheel bolts.
I used it for my rear in my W204 C180K but it was a bit too aggressive as i have also lowered 20mm with H&R springs, thus causing some rubbing on the drivers side. Seems to be the case for RHD mercedes that rear drivers side stick out a bit more than left. (I found out the same issue with my C63 as my rear wheels with ET40 had to be mill 3-4mm to enable fitment)
Will suit those who have not lowered.
PM if any questions.
Thanks.
Postage extra.
Thanks.
