I have a shift/gear problem which is really bad in the morning when the car is cold.
When I set off the car accelerates normally but seems to hold onto the gear then it will jolt into the next gear and start to surge like I'm on and off the accelerator?
Same into the next gear up, again whilst accelerating normally the car jerks and you can visibly see the rev counter needle bouncing up and down?
The really odd thing is the car does not go into limp mode and there are no fault codes from the ecu?? There is enough of the correct oil in the box.
Any ideas? Hope you can help, many thanks Carl
2004 Facelift so I don't think its a valeo radiator but how can I tell for sure?
