I am after some advice as to what the problem might be and some alternative solutions as I just know the dealer will charge a small fortune!
The problem seem to occur in the mornings, but once it starts, the car works fine until the next morning. Basically, when I turn the key, all manner of fault lights appear on the dashboard. The key turns and the car starts alright, but nothing, from the power steering to the indicators seem to work. Turning the ignition on and off a few times used to work and after a few tries, the radio came on, the wipers worked and all were fine for the day. It has since become unmanageable as it now takes up to 15 min to work, so I have booked it in the dealers to locate the fault.
I’ve recorded a clip and uploaded it to youtube showing what happens when I turn the key. See here: https://youtu.be/gzoBT9f-fDI
The car is a 2012 C220 diesel if it is of help.
I thank you I advance!
