amazighman
- Apr 22, 2016
- CLK 430
Hello.
I have successfully removed the rear subframe from my CLK 430...and all went well .
I have fabricated a wooden platform with wheels to be able to move the subframe around the garage and out for blasting.
The only issue I have is the handbrake cable is attached to the subframe via a rubber loop and it goes to the mechanism in the back seats.
I have tried to remove it from the back seats .I have disconnected it from tensioner ,but I got stuck where it goes out through the body shell.
Wis claims you must have a tool to remove it or break it and buy new one and that tool is mega expensive for little spanner 1 time use....
Any help will be very appreciated..
