PJayUK
- Oct 6, 2008
- Location
- Surrey, United Kingdom
- ML320 W163, E320 W210 & Jaguar X300-XJR6
There are four wires that connect to a block connector that in turn connects to the mirror glass. The middle two are both brown and connect to the glass via a pair of contacts on the middle right hand side of the rear of the glass. The outer two are striped pink-red and black-pink and connect to red and black wires that also connect to the glass but to the bottom and top edges of the mirror under the plastic backing plate. I am getting a steady 14V on the two central brown wires but nothing on the two outer wires. I was wondering if anybody would happen to know which wires are which? If I can identify the heating element of the glass it would help me diagnose whether its getting power or not.
Thank you.....
Thank you.....
