Horrgakx
Hi all - I just can't find a definitive answer as how to get speed cameras (or other POI's for that matter) on my COMAND ONLINE Satnav system.
Does anyone know how??
W205 C Class
W205 C Class
Guys done everything according to instruction, generated PersonalPOIs.gpx file uploading it into SD card PersonalPOI folder, in Comand Online NGT 5 there is no Personal POI option, however I receive alert signal and warning but icons themselves are not displayed on road, anyone got a chance to make them appearing ? I have C250 AMG 2014 Comand Online NGT 5
There should be an option called "Visual warning for personal POIs" within the personal POI settings on your Comand system. Make sure this option is ticked.
Malcolm
I tried doing all of this but the system doesn't recognise there's anything on the memory card.
My Garmin Map Pilot on Audio 20 does not recognize additional POI. I added the National Trust POI file in .gpi format to the SD card, folder POI. The SAT NAV does not recognize these POI , it just ignores the new file.
I contacted both MB and Garmin customer services , but they provide little help referring me to each other. Any help will be appreciated.
I would also like to add Speed Camera POI.
Thank you.
Thank you SG94,I have an extensive thread in PGPSW on this issue.
Prepare to be disappointed.....
I'm also struggling to add POIs to my car. I believe I have NTG 5.5.
Anytime I try to import Personal POIs, it's just stuck on Importing data (this may take several minutes).
I dont know what it is I'm doing wrong
Sorry Nick, you are out of luck. The functionality to load Personal POIs from SD card has been removed from NTG 5.5 on the new E class. There's no menu option to do this on your version of Comand. Sad but true.
