Eee21
Hi all how do I change the front turn signal bulbs I cant seem to get to them. ? thnks On a ML W166
Yes sorry not the H7 bulbs, There does not appear to be anything in the book about the front signal bulb replacement. Surely you don't need the dealer to change them.Can't help with getting at them but it should be in the owners manual. I think you'll find H7's are headlight bulbs.
It has 2 on each side, located on the bottom of the headlamp, in twist-in bulb holders. They face up over from the bottom, so they are quite tricky to access without pulling the wheel arch liner away for the outer ones. The inner ones are just about workable from in the engine bay from above.
