HOW TO: change the automatic gerbox oil and flush on a 722.6 'box
BlackC55
Portsmouth, Hampshire.
E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Here is my how to on an ATF change on a 722.6 box.
There are loads of pics.
First pic of the car in question a E320 W210. Make sure the engine is hot. At least a 20 min road test
These are the parts needed. ATF 000 98921 03 10. Dipstick,filter pipe and sump seals.
Raise the car up and drain the fluid from the gearbox sump pan. Use a 5 mm Allen key and tap it in with a hammer. They can be very tight.
Let the old oil drain out. As you can see this ATF is pretty dirty. Remember to dispose of the oil in the correct manner. About 3.5L will drain from here.
Then undo the heat shield from the right hand side of the 'box.
The next step is to undo the sump pan retaining bolts. There are 6 of them. Again tap the torx socket in with a hammer. They bolts can be tight and have been known to snap off. Be very careful here. About 30% of the cars we do these bolts snap off. Only attempt it if you have the ability to drill them out if necessary.
Start with the front right bolt and unscrew it halfway. NOT fully.
The item above is called a pilot bushing and they often leak here. The part number is 203 540 02 53 for it.
Leaving the right front bolt in allows the fluid to drain from the drain hole until the sump is fulley drained.
Remove the old filter and install the new one. Give it a thump to loacte it. They tend to hang down a bit. This is normal. Note the loacting clip.
Use solvent cleaner such as brake cleaner.
The sump pan bolts have to be cleaned up on the wire wheel and the threads greased with heat resistant grease.
The pic is of some brake grease that I use for ceramic brakes.
This is a picture of the old bolts. They seize in so hence the reason for cleaning them
Clean the gearbox up where the gasket sits, of old ATF
Put the sump anp back up and make sure the gasket is secure on the pan. Hold the pan up and with the other hand use a brace to do up the bolt. Only do it up lightly at first. Put all 6 in and make sure the pan is straight and square to the box.
Torque all of the bolts up to 8NM
Re-fit the sump drain screw and torque to 20NM.
Clean area with brake cleaner. This is so when we re-fill it we can check for any leaks
Re-fit the heat shield.
The next step is to fill the gearbox with 3L of fluid from the dipstick hole in the engine bay.
Push the retaining clip through the cap and discard. Remove the cap and start filling. A small funnel and pipe is what I use.
Great to see the level of work and attention to detail that goes into this! I have had Olly do the transmission fluid on my old CL and on the current S Class - prevention is far far cheaper than the cure (a new gearbox).
The next step is to flush the remaining oil out.
Firstly remove the banjo bolt from the left cooler pipe attached to the bell housing. You will need a 19mm socket and ratchet. Discard the two old seals. Oil will drip from here so have a drainer ready.
I have made a drain pipe from an old banjo bolt that I screw in the hole. This allows the fluid to drain into a container.
Whe the pipe is secured start the engine and leave running for 4 mins. This allows the torque converter to drain.
Then remove the pipe and re-fit the banjo bolt with new seals.
Do up tight but not too tight.
