lars-mad
- Jan 9, 2011
- Location
- nearby Oslo in Norway
- 1996 c180 2.0 1995 C180 AMG 1988 190e 2.3 1989 230CE with facelift
Hello how do i check the atf fluid level on my c200? i suspect that the level is low
Amazed it actually has the dipstick. That said, oil less red in appearance than I thought it might be!
m.
The older w202's had a gearbox dip stick. The newer ones don't but you can get a workshop dip stick cheap. If the ATF is not clean looking, it could be in for a flush and filter change
i always thought the mercedes auto boxes were sealed for life.
just bought a 1998 c250 myself, as its 14 years old now and has 129thousand on the clock should i consider getting the gearbox oil changed ( auto box) do i have to get a merc dealer to do it or can any decent garage do it and is there a filter /seal kit i need
cheers guys
Stoobzie said:My question is much the same. recently bought my c180 auto so i can drive to hospital appointments with a broken leg. i know enough about cars to carry out work myself but nothing about an auto. my merc changes at low revs when it is driven from cold, but now when the car has been driven a few hours before, and is then cold again it wont change into 3rd untill it goes all the way round to 3000rpm, then a bang into gear when it does go? once the car is warmed up all works perfect and smooth but is increasingly rough when the box is colder? is this normall ? also the box's dipstick is very hard to read and normally shows oil half way up the stick! thanks, chris
