rjhfandclf
- May 2, 2015
- C220 Sport ED125
Hello,
I recently acquired a 2011 'facelift' C220 Sport with Comand Online NTG 4.5.
I do NOT have (and certainly don't want) a smartphone of any sort, so don't use probably the main reason for 'online'. However, after some initial reluctance, I now find the Comand system very good, and use the SD slot readily for music. However the Navi is much frustrating me with its apparent programming inflexibility. It may be that I am just being an 'Oldie'!
Prior to this I have always used Garmin GPS (both for car and hand-held walking), to both of which I have always been able to download extra POIs and routes with great ease - created either in Garmin Basecamp or Google Earth. I have searched everywhere, but cannot find any obvious way of doing this with MB Comand (without using a particular range of mobile phones - all of which I consider an invasion of privacy!)
Using the obvious SD card, I've tried to import .KML, .GPX, .KMZ, and have even tried using the MB POI Loader programme to convert to Personal POIs (although I have no idea how odd this might appear even if accepted in Navi), but Navi refuses to recognise any of this.
The only thing that I can think of that I may have failed with is in trying to load from the SD card when it says it is importing information to Personal POIs - 'this might take several minutes'. I have left it for about 10-15 minutes, but nothing further happens. To be frank, if it DOES take that length of time to import a route file then it is useless anyway.
Am I 'pushing water uphill with a rake' or is there some nifty trick I am missing? Any help would be much appreciated - thanks.
