Intermittent ABS and ESP warning light
Discussion in 'Engine' started by trooper1, Oct 10, 2011.
  1. trooper1
    trooper1 New Member
    11
    Oct 10, 2011
    Car:
    2001 E55
    Hello, I am new to this forum.
    I have been running an '01 E55 estate for 2.5 years and thoroughly enjoy it. A great mixture of pace, space and stealth.
    However, every now and then the ABS and ESP (i think it is ESP) warning lights appear on the dash board telling me to go to a garage. The strange thing is the warnings disappear when the engine is turned off and re-started. This happens every so often and I have not worked out a pattern. We live in London so wondered if it occurs because the engine is too hot (i.e. traffic) or if there is a loose connection i.e. related to my wife driving over the dreaded speed bumps too quickly?
    Can anyone please help?
  2. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,087
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, MK1 Caddy, S500, etc
    It needs to be plugged in to a Star to see what is causing the fault.
  3. OP
    OP
    trooper1
    trooper1 New Member
    11
    Oct 10, 2011
    Car:
    2001 E55
    ok - thanks. I will keep you posted.
  4. Dichtung
    Dichtung Hardcore MB Enthusiast
    267
    Oct 16, 2007
    N.W.
    Car:
    W210 300td, W203 C180K
    Speed bumps?
    My car started with similar problem.
    Turned out to be wire from Passenger seat junction box to sensor embedded in the seat squab.
    They continually flex with passenger weight and eventually start breaking, and switching the ESP light on.
    Just a thought. :thumb:
  5. Howard
    Howard Hardcore MB Enthusiast
    18,624
    Apr 23, 2004
    Toad Hall
    Car:
    CLS 500 / A 150
    Would that not illuminate the SRS light , not the ESP ?
    The seat squab is a common fault of SRS light illumination , it isn't connected to the ESP system.
  6. Dichtung
    267
    Oct 16, 2007
    N.W.
    Car:
    Sorry Trooper; Howard is correct. :doh: Just been out to the car to check.
    The SRS light on the dash, and the little airbag light, next to the gear selector.
  7. RBYCC
    RBYCC Hardcore MB Enthusiast
    1,131
    Aug 8, 2007
    REHOBOTH BEACH DE USA
    Car:
    1971 280SL, 1988 300CE TT, 1994 E320 CAB, 1999 AMG C43, 2005 AMG G55K 2008 CLK63 AMG BLACK SERIES
    See below....sorry for the duplication, something went wrong with the posting !
  8. RBYCC
    1,131
    Aug 8, 2007
    Car:
    Trooper
    A few possibilities...
    ABS and ESP warning lights coming on when a true fault condition does not exist are typical of a system low voltage...anywhere from battery to voltage regulator to alternator.
    You may also want to check if your car has a brake light switch which if faulty can also trigger the lights.
    If the lights stay on, in some models they can be reset by turning the steering wheel left to right full lock with the engine running.
    Ed A.
  9. OP
    OP
    trooper1
    trooper1 New Member
    11
    Oct 10, 2011
    Car:
    2001 E55
    Sorry for the late reply and thank you very much all your responses.
    The issue is still ongoing. I am going to book it in with an expert - will keep you posted.
    Does anyone have any recommendations for Merc specialists in south London?
    cheers
  10. OP
    OP
    trooper1
    trooper1 New Member
    11
    Oct 10, 2011
    Car:
    2001 E55
    Ed A,
    Before I book the car in - are you suggesting the problem could relate to an issue with the battery's power (or lack of)? We live in town so most journeys are stop start and we only do c7k miles p.a. Surely, this behaviour will drain the battery, which may prove your theory correct.
    I checked and all brake lights work.
    Many thanks.
  11. Bellow
    Bellow Hardcore MB Enthusiast
    3,184
    Apr 26, 2010
    On Smarts this issue is frequently caused by:
    Mismatched tyre (including incorrect pressures)
    Faulty brake light switch - very common.
    Corroded reluctor (ABS) rings.
    Driving over speed humps - but this merely activates the ESP briefly.
    Check the simple stuff first. If it is fine prior to first application of the brakes - suspect brake light switch.
  12. Bellow
    3,184
    Apr 26, 2010
    If as per smart (smarts have Merc input), the switch has dual contacts. One set for the lights and another for ABS/ESP etc. Guess which is the vulnerable set!
  13. flt.eng
    flt.eng Hardcore MB Enthusiast
    212
    Oct 20, 2010
    Nr. Tewkesbury
    Car:
    E320 avantgared
    Where is this brake lght. switch.
  14. 24 VRT
    24 VRT Member
    52
    Oct 1, 2010
    North Hampshire
    Car:
    '99 W210 E320CDI A/garde Estate
    I had the same problem with my '99 E-class. Its the battery voltage being too low when you start up. Go for a drive and re-start and the warning lights / message go away. All those short journeys will run the battery down and it gets worse as the colder weather comes along.
    All I do now is leave the old girl hooked up to a CTEK battery conditioner and the problem's gone. Not necessarily easy, however, if your car is parked on street when not in use!
  15. Bellow
    3,184
    Apr 26, 2010
    On a smart fortwo it's under the floor - as is the master cylinder and servo.
    On a more conventional car it should be easier found - somewhere close to the master cylinder, or on the pedal.
    1 person likes this.
  16. Oneilly
    Oneilly Active Member
    71
    Feb 14, 2011
    Luton
    Car:
    Good info
  17. nadeem.akhtar
    nadeem.akhtar New Member
    1
    Nov 3, 2013
    Bedfordshire
    Car:
    E220 CDI (W211)
    Hi trooper1
    Have you resolved the ESP error problem? I am experiencing the same issue on my E Class E220 CDI (W211 - 53reg). I only receive ESP error, I don't see ABS, BAS errors on my dashboard. As soon as the car is switched off and re-started, the error goes away.
    My outside temperature reading is extremely high, so I have bought a new temp sensor but haven't yet fitted. Also, when the heating is on, coolant temparature does not go beyond 1 bar (40 or 50 C). if the heating is off, temparature does go to about 80 C.
    Are these all related to one problem? if so, what could it be be?
    Many thanks for your help.
Share This Page
