jerking effect
BIG_G_1979
N.Ireland
E280 CDI SPORT
Hi guys I have noticed that my e280 cdi with 7g box jerks the odd time once cold once warmed up its fine any ideas?
What I mean by jerks is that when accletoring it seems like it's changing up and down up and down on gears anyone had this issue
Sent from my xperia z3 using MBClub UK
Probably the gearbox adaptations need resetting. Or the electro plate on its way out. Or fluid needs changing. Is the fluid at the right level? I would get it reset first, and make sure the level is correct.
Thanks guys it's booked in for a transmission service Monday week as said only started to do this and only jerks for a few seconds but not everytime so hopefully oil and filter change we sort it out
It could be a turbo issue too. They are common for it. Get the codes read too.
Make sure the correct fluid is used.
Get the oil changed by MB or indie, it is not a DIY job. When cold the first gear change is never very sooth, once warmed up changes are very smooth.
Yes guy performing job is a merc indie and only uses merc oil and filter thanks guys
