My 1993 320ce cab has finally arrived and having spent the day with it I have a couple of small problems.
1. The drivers side heated seat switch only lights up in single light mode, and not the other way to double lights (rapid setting). Is this a switch problem?
2. It has an aftermarket immobilizer that needs turning off if you turn the car off, and need to start it again. In other words, I cannot start the car if I am sitting in it if I do not 'open' the doors first. Can this be altered to not do this?
3. the door windows seem to protrude up by a few mm when in the up position, making it hard to close the doors properly without giving them a firm pulling. Can this be adjusted? Can the glass be tightened so that it does not seem slightly loose (side to side) when you open and close the doors
4. the power steering is a little heavy, does this mean the pump might be at fault or are they all like this?
5. there are a few minor rattles and squeaks inside the car, would silicone spray be the best way to deal with these or is there a better remedy?
Otherwise the car is really lovely and a pleasure to drive. Will post some pictures soon.
