^^^^^^^Having had K&N and the like in the past, I think the best thing about them in previous cars was the air induction noise but in terms of performance I rarely felt any sort of difference
If they're open cone filters then you'll get a great noise but at the same time likely suck in warmer air so may even be detrimental to the performance. I've had cone filters on a couple of cars though and they do sound awesome though.
Panel filters are probably better than OEM and you can clean and re-use them, something like a million mile warranty on them I believe. Not sure they'd offer any other benefits though really.
IMO i would stick to oem items.Are K & N filters worth fitting to my W211 E500?
Obviously there website sings their praises - but no idea if its worth the £80 - or do I just stick with original ones
If the engine is standard then in most cases the OEM airbox is best, however with modified units (as this OM606 clearly is) there are other factors to consider, including packaging constraints and/or as in this case the required airflow that a filter has to cope with.
I can guarantee that the standard OM606 airbox with its cold air feed would not be able to supply the required airflow of 27,000ltr/min and would result in a substantially lower power output.
I’ve always preferred BMC to K&N after problems with oil fouling the MAF
