Key Battery - Is this repalced at every service?
Discussion in 'General Discussion' started by MSG2004, Aug 16, 2017.
  1. MSG2004
    MSG2004 Hardcore MB Enthusiast
    382
    Feb 5, 2005
    Car:
    GLE, AMG Line
    Hi
    We bought a brand new GLE in April last year.
    Rarely open the windows via remote control but noted this summer the windows would not open via remote. However, the open/lock and open/shut boot worked well from close by and distance.
    As it got hotter I thought I'd try the new/spare key and window auto open/close.
    The car was service April 2017, noted windows not opening around March 2017 and started using the spare key a month ago.
    Paid around the 300 quid mark for the 'A' service.
    Question: does MB replace the key battery and do you think the key is at fault. I have noted on my previous 2 C class cars that auto/key window open is a hit/miss thing but when I first got the GLE, you could open windows from about 20 feet.
  2. brucemillar
    brucemillar Hardcore MB Enthusiast
    7,068
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    It is hit & miss usually rendering it almost useless. The issue seems to be the receiver and NOT the key (transmitter). You have to hold the key against the receiver/door handle, to get it to function.
    1 person likes this.
  3. John N
    John N Hardcore MB Enthusiast
    269
    Mar 22, 2017
    Peterborough.(Scot on Permanent Tour!)
    Car:
    C250d 4 Matic
    The Key Fob Battery was replaced on my A220d on the second/2 Year Service, they also gave me one for the Spare Key Fob
  4. garycat
    garycat Hardcore MB Enthusiast
    174
    Jan 29, 2017
    Bristol
    Car:
    2014 C Class 220CDI Coupe
    On mine, the windows will only open via remote if the key is pointed directly at the drivers door. Always been that way, even with a new battery.
  5. renault12ts
    renault12ts Hardcore MB Enthusiast
    14,244
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    I don't know whether they change the batteries at a service. But, if you suspect a new battery might help, they are cheap and easy to fit.
  6. OneForTheRoad
    OneForTheRoad Hardcore MB Enthusiast
    540
    Apr 20, 2015
    durham .
    Car:
    e320 w211 04/05
    The key uses infra red to work windows. Just like a tv set you need to be close. Drivers handle should have a small black square which is the receiver.
  7. renault12ts
    14,244
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    He did say it originally worked at about 20 feet.
  8. st13phil
    st13phil Hardcore MB Enthusiast
    5,918
    Nov 6, 2007
    North Oxfordshire
    Car:
    His - Diamond White W212 E63 Biturbo with Night Package / Hers - Obsidian Black R172 SLK55
    Key fob batteries (only the one you present with the car at service time) are changed at the B service, i.e. every two years for most people.
  9. Rory
    Rory Hardcore MB Enthusiast
    6,992
    Mar 12, 2005
    Cheshire, UK
    Car:
    C270CDi Estate (2004 facelift model)
    I found I always had to ask for it to be done. And give them the second key so they'd do both. Was always very nervous giving them both keys!
  10. ioweddie
    ioweddie Hardcore MB Enthusiast
    741
    Sep 16, 2012
    Winford Isle of Wight
    Car:
    AMG Line Premier Plus Estate C220d
    Mines done at every service by esplanade iow
  11. OP
    OP
    MSG2004
    382
    Feb 5, 2005
    Car:
    GLE, AMG Line
    Thank you all. To clarify, intially worked from about 20 feet as does the spare key now. The first key wont opn or close windows even when put right up to the sensor. The car is still under the new car warranty, may have it looked at next year.
    Btw, today, as I put the car into reverse to park at the local supermarket, the reverse cam picture turned while all i could see was the coloured marking, took it out of reverse and back several times no joy, drove it around the car park, no joy, then just before we left the shops, put it into reverse the camer worked - will keep an eye on this.
    thanks all
  12. renault12ts
    14,244
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    You're patient/odd. You posted a thread about a problem and got answers including change the battery and you'll wait 'til next year.
  13. flat6buster
    flat6buster Hardcore MB Enthusiast
    569
    Sep 8, 2009
    Bath-ish
    Car:
    C350e, 911sc, S320, CLK500 convertible
    But will presumably use his spare key until then, so no problem?
  14. oldguy57
    oldguy57 Hardcore MB Enthusiast
    667
    May 20, 2015
    Lancashire
    Car:
    sl350/ Tri Chevies / Vauxhalls
    Think I would just replace the batteries now anyway - £5 ish and available everywhere including Halfords. The Cl told me on the dash when the batteries needed replacing (without prompting)- is this function not common on the newer stuff?
  15. Petrol Pete
    Petrol Pete Hardcore MB Enthusiast
    877
    Nov 11, 2016
    Petrol stations ...everywhere
    Car:
    C55 AMG Wagon
    My car is much older and one of the keys is not the original but both work on the auto window/sunroof ...but it can be a bit hit and miss. I tend to be close to the car when I use the function (pointing the key at the square on the door handle) but it appears to work better when the sun is NOT shining brightly....just the kind of time that you might want to use the function if the car is hot inside :cool: !
  16. Happytalk73
    Happytalk73 Hardcore MB Enthusiast
    4,227
    Sep 10, 2015
    South West Scotland
    Car:
    Vito
    I think the convenience opening/closing on MB's is hideous. You have to point key inches away from the drivers handle and then once activated you have to hold button pressed throughout the whole process. Easier/quicker to just close the windows & sunroof before you get out of the car.
    Fords Globel opening/closing is a much better system. Can be activated from within 20' of the vehicle and once it's started you can let your finger of the button and walk away/get in the car.
    Also the Ford charges the key every time it's in the ignition whilst driving so never any need to change the battery. Simple efficient thinking from Ford.
  17. anderoo
    anderoo Active Member
    66
    Jun 21, 2016
    Car:
    C350 coupe
    I don't know if the keys for new cars are different, but it's very easy to change the batteries myself in my keys, and they are extremely cheap. So no need to wait for any particular service.
  18. kianok
    kianok Hardcore MB Enthusiast
    977
    Feb 12, 2011
    Leeds
    Car:
    E220 AMG line premium plus coupe
    My car is having a little holiday at the dealer for a few days so I might ask them to change the battery when I pick it up.
    With all the extra presses from remote closing the windows and disabling keyless-go it must be on its last legs by now :D
  19. kianok
    977
    Feb 12, 2011
    Leeds
    Car:
    Never had to do it until today. A message popped up on the dash requesting me to replace the key battery.
    Very simple to do using the actual key that slots into the fob to release the case.
Share This Page
