key fob case change
killnerh
west sussex
clk 320
hey guys i have bought a replacement case from ebay i cant seem to find any videos on you tube to tell me how to change all the insides over. I cant find away for it to come apart i have removed the battery does any body know that if i just pull on the circuit board will i destroy every thing or will it just slide out and then in to the new one any help guys would be great thank you. :thumb:
You have to first describe what type remote fob you are talking about and what year is the car?
Dec
its a 2000 clk 320
the key fob is black all over it has 3 buttons lock unlock and boot open
and has the silver blade key in the top its the one that you take the key out the top then use the key on the lever to get the battery to slide out.
all done all changed over and it all works :) the board was slightly different to the one in dec's photos the spacer board was connected to the circuit board o just had to use tweezers and slide the hole board out then in to the new case so all is good.
thanx for your help guys.
