Am new to the site but have just bought the above. Have read that there was a problem with leaking on the metal roof but was assured by the dealer that this would not be a problem on this car and you would "smell " the damp if it was happening, and yes I know that you should never believe what you are told! Well sadly whilst parked on the drive at a slight angle it does leak. ( can only assume previous owner garaged it !)
I am sure this topic has been discussed on the forum but any helpful advice would be much appreciated as to solving the problem. The drain holes are clear and not blocked etc so it has to be the rubber seals . Is there a fix without having to replace all the seals etc.
Thanks in advance
Thanks in advance
