Leaky SLS Pipe
gbjeppm
Surrey
C207 E Coupe 350cdi, W166 ML 250 Cdi Sport, R171 SLK 350, Suzuki V Strom DL650
I am slowly getting to grips with the 560 sec I recently acquired.
After cleaning up the SLS pipes that looked pretty badly corroded, I have discovered a slow leak.
I planned to replace them anyway, so looks like I need to at least do the leaking one now.
Can I replace them with copper lines that I plan to make up myself? Or is there a reason I should stay with steel?
Thanks in advance.
Many thanks
Cupre-nickle would be ok, copper might not be strong enough and can work harden and fracture.
What size are they?
Sls pipes are thicker bore than brake pipes..
I had mine made up at hose and pipe supplier.. The ones mb sent came in long lengths and there was no way I could bend them to fit..
Oops, Oh well, I need to do the brake pipes anyway. Hopefully the kit will still be useful with thicker bore pipe.
Will report back when I start the job, as they really look the same to me, time will tell, thanks for the input Jay.
