Hey all changed out the side lights on my w211 lights up and works but there is a fault message, I have swapped the bulbs around and tried them both ways around and the same fault is there.
The car has had a bump there a few years ago and the wiring has been modified as the head light was replaced, is it a bumper off to get the light out might solder the wire and remove the spade connectors, could there be corrosion on the connector making the resistance making a fault show, was ok with the normal bulb.
