Steve260E
Hi
I noticed if you order the Lemforder wishbones for a W124 you get a selection of nuts and a bolt with it.
Could someone tell me what these are for? I'm guessing the bolt and one nut is to replace the ones on the ball joint, two others are for the anti roll bar but that still leaves two more that I'm unsure about.
I'm wondering if they are nuts for the eccentric bolts which I was going to replace anyway as mine are well and truly rusted so will probably need cutting when it comes to replacing.
Here is a link to the wishbones in question
>>Lemforder wishbones<<
Cheers
Steve
Cheers
Steve
