Uav Pilot
I have recently fitted new upper arms and two new struts one front left and one rear right, the rear one was built by myself out of two bad struts to make one good strut.. Now the problem I am having is the car is sitting about 10mm or so lower on the left hand side which isnt uncommon apparently even with perfect cars?? anyhow I have tried to rectify this by performing a level calibration using STAR DAS I adjust the levels so that the car is sitting at 70cm from floor to arch all the way around and the voltages are as follows FL2.08 FR2.29 RL2.18 RR2.08 So as far as I am aware within acceptable range? ( 2v-3v) Now I dont have a Romess inclination tool but enter the inclinations as 2.6 for the fronts and -3.1 for the rears which is also within range but I get the error "Level calibration not successful level sensors not within range" So it wouldn`t bother me too much as the car doesn`t sit too bad and yes I probably could level it with adjustable links but now I have a constant ABC warning on the dash and the fault code is the level calibration not successful so until I can calibrate with success I will have the error on the dash!
Any help will be appreciated
