I've noticed a noise appearing from the driver's side front wheel area on my manual 2.5-16, it sounds like a squeeking/squeal type sound which is more noticable when steering.
I haven't driven the car for a couple of weeks, jacked it up to have a very quick look but I haven't got anyone else here today to move the steering etc whilst I'm looking/listening. I have a feeling it's coming from the lower ball joint fitted into the wishbone.
Has anyone replaced these on a W201, I'm sure they're probably similar to the W124s etc, but from a quick search I can't tell if they need a press etc to fit?
The part appears quite cheap - less than £15 a side! I think complete MB wishbones with the ball joints/bushes etc are around £200 or I guess I could've replaced the wishbones if the joints are really that hard to remove/refit.
I don't mind spending the cash if it's worth it but I don't think there's anything else really untoward. It's a great smooth driving car and has had a good going over of the steering/suspension etc a few thousand miles ago and no reported problems of excessive wear/play on any parts during MOT time or inspections.
I'm guessing that a recent drive where I got caught out in some rain, plus the limited use and cold weather might have caused the joint to become dry/washed out hence causing this noise? Doesn't appear to be any other problems.
Any advice/pointers much appreciated, just wish it'd warm up/brighten up a bit again!
Cheers,
Will
Cheers,
Will
