richard300
- Nov 10, 2005
- Location
- West Sussex
- CLK230Kompressor (factory AMG sport pack) & Jaguar XJ8 (X308)
I always felt my car had a slight misfire (barely detectable, to the point that i thought i was imagining it) Today though, after a 15mile motorway journey i pulled to a stop, the revs dropped and the car has had a very notable missfire since.
I changed the plugs 3 months ago, so (currently i am ruling them out) i had a spare (new) coil and swapped them over one by one - That made no difference.
Removed the MAF and that made no difference.
I did notice that the hose from the MOT valve to the engine had come off, but i re attached that and nothing changed.... on the subject of the MOT valve (or whatever its called) should i hear this making a constant clicking noise? because i cant.
I have ordered a set of 3 leads, which will hopefully be here tomorrow. But when i pull every lead/coil away from the spark plugs i do hear a spark/arcing from all six of them, so not sure this will help.
There is also a tapping/hissing noise that i can hear - cant make out if its from the rear of the engine, the rear exhaust manifold or the front section of the exhaust as i can hear it under the car. However, someone told me that was un-burnt fuel in the exhaust system as a direct result of the misfire.
I live in Australia (moved from the UK in April) and nobody wants to touch it, and the nearest (alleged) specialist is 50km away....
The wiring loom seems to be in good shape, it's either a car with the later loom or its been replaced.
