MAF cleaning - an option?
fabes
Southampton
E 400 Coupe and X-Trail
Hi
Bugga....the day after a service I get an EML and its the MAF apparently.
£250 to replace...... (plus an hours labour?)
How good a long term option is cleaning it as I am stretched this month and really could do without forking out for a new one?
Read a few threads and it seems possible, but is it just buying time?
61k on an 09 reg CLK (short journeys mainly I will admit) but miffed its thrown a light up.
Views would be appreciated?
Cheers
What type of MAF does the CLK have? - I've had good results cleaning hot wire MAFs with throttle body cleaner before, but I don't know if that's applicable in this case.
It's.going to.be swapped out for another on Tuesday at the garage. Will see if a quick clean will help. As a backup though I have bought a Bosch one from ECP as they have a store nearby and they have an upto 55% weekend on at the moment.
I can always return it but it's £100 less than I was initially told.
Those on line (german) parts stores didn't have a good rep, and considering I might need a refund, I opted ECP.
Bosch MAF fitted, MPG up (a bit....) and car running smooth again as the hunting was getting worse.
That had better be it for a couple of months now as I am bleeding money at the moment between services and MAF's etc....:wallbash:
Its been £1,200 in services, maintenance and parts in 18 months! (not counting tyres)
Spark plugs and MOT in late June.....
A good blast with some brake/ carb cleaner, has worked for me many times, not had to do it on a Merc yet though, I must admit.
I bought a cheap copy MAF for our BMW, lasted 2 days before it failed :fail
put the old 1 back on after cleaning it and its been fine since :thumb:
