manual seat not moving forward
martin123
Hi only had my mercedes c180 coupe 02 plate to days and the drivers seat has stopped working it will wind backwards but not forward s .has any one had the same problem .or know how to repair
Hi I have the same car if you take the strain then try winding it up other than that you may have to take the back cover off to see what the problem is.
Found the problem a spring had broken inside the wilded plastic ...
Had to do a quick fix .
Had the gagage look at the car because it started running rough ...seams someone had disabled the engine warning light on the dash ..
Engine is suckling in air been told it about 600 pounds to fix ...and thers also oil in the water .
Only had it for a week .
Never agine thort mercedes where good machine s ...wish I had got the alfa I was looking at
