Mercedes-Benz Diagnostic Trouble Codes (DTC)
Discussion in 'Electronics' started by Koolvin, Jan 17, 2003.
  1. Koolvin
    Koolvin Administrator Staff Member
    9,968
    Jun 1, 2002
    Staines innit
    Car:
    W168, W169 & S202
    Mercedes-Benz Diagnostic Trouble Codes (DTC) for 1996+ models
    Powertrain
    P0100 Mass or Volume Air Flow Circuit Malfunction
    P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
    P0102 Mass or Volume Air Flow Circuit Low Input
    P0103 Mass or Volume Air Flow Circuit High Input
    P0104 Mass or Volume Air Flow Circuit Intermittent
    P0105 Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
    P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
    P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
    P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
    P0109 Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
    P0109 Intake Air Temperature Circuit Malfunction
    P0111 Intake Air Temperature Circuit Range/Performance Problem
    P0112 Intake Air Temperature Circuit Low Input
    P0113 Intake Air Temperature Circuit High Input
    P0114 Intake Air Temperature Circuit Intermittent
    P0115 Engine Coolant Temperature Circuit Malfunction
    P0116 Engine Coolant Temperature Circuit Range/Performance Problem
    P0117 Engine Coolant Temperature Circuit Low Input
    P0118 Engine Coolant Temperature Circuit High Input
    P0119 Engine Coolant Temperature Circuit Intermittent
    P0120 Throttle/Petal Position Sensor/Switch A Circuit Malfunction
    P0121 Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
    P0122 Throttle/Petal Position Sensor/Switch A Circuit Low Input
    P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
    P0124 Throttle/Petal Position Sensor/Switch A Circuit Intermittent
    P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
    P0126 Insufficient Coolant Temperature for Stable Operation
    P0130 O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
    P0131 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
    P0132 O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
    P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
    P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
    P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
    P0136 O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
    P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
    P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
    P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
    P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
    P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
    P0142 O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
    P0143 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
    P0144 O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
    P0145 O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
    P0146 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
    P0147 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
    P0150 O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
    P0151 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
    P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
    P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
    P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
    P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
    P0156 O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
    P0157 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
    P0158 O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
    P0159 O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
    P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
    P0161 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    P0162 O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
    P0163 O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
    P0164 O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
    P0165 O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
    P0166 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
    P0167 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
    P0170 Fuel Trim Malfunction (Bank 1)
    P0171 System too Lean (Bank 1)
    P0172 System too Rich (Bank 1)
    P0173 Fuel Trim Malfunction (Bank 2)
    P0174 System too Lean (Bank 2)
    P0175 System too Rich (Bank 2)
    P0176 Fuel Composition Sensor Circuit Malfunction
    P0177 Fuel Composition Sensor Circuit Range/Performance
    P0178 Fuel Composition Sensor Circuit Low Input
    P0179 Fuel Composition Sensor Circuit High Input
    P0180 Fuel Temperature Sensor A Circuit Malfunction
    P0181 Fuel Temperature Sensor A Circuit Range/Performance
    P0182 Fuel Temperature Sensor A Circuit Low Input
    P0183 Fuel Temperature Sensor A Circuit High Input
    P0184 Fuel Temperature Sensor A Circuit Intermittent
    P0185 Fuel Temperature Sensor B Circuit Malfunction
    P0186 Fuel Temperature Sensor B Circuit Range/Performance
    P0187 Fuel Temperature Sensor B Circuit Low Input
    P0188 Fuel Temperature Sensor B Circuit High Input
    P0189 Fuel Temperature Sensor B Circuit Intermittent
    P0190 Fuel Rail Pressure Sensor Circuit Malfunction
    P0191 Fuel Rail Pressure Sensor Circuit Range/Performance
    P0192 Fuel Rail Pressure Sensor Circuit Low Input
    P0193 Fuel Rail Pressure Sensor Circuit High Input
    P0194 Fuel Rail Pressure Sensor Circuit Intermittent
    P0195 Engine Oil Temperature Sensor Malfunction
    P0196 Engine Oil Temperature Sensor Range/Performance
    P0197 Engine Oil Temperature Sensor Low
    P0198 Engine Oil Temperature Sensor High
    P0199 Engine Oil Temperature Sensor Intermittent
    P0200 Injector Circuit Malfunction
    P0201 Injector Circuit Malfunction - Cylinder 1
    P0202 Injector Circuit Malfunction - Cylinder 2
    P0203 Injector Circuit Malfunction - Cylinder 3
    P0204 Injector Circuit Malfunction - Cylinder 4
    P0205 Injector Circuit Malfunction - Cylinder 5
    P0206 Injector Circuit Malfunction - Cylinder 6
    P0207 Injector Circuit Malfunction - Cylinder 7
    P0208 Injector Circuit Malfunction - Cylinder 8
    P0209 Injector Circuit Malfunction - Cylinder 9
    P0210 Injector Circuit Malfunction - Cylinder 10
    P0211 Injector Circuit Malfunction - Cylinder 11
    P0212 Injector Circuit Malfunction - Cylinder 12
    P0213 Cold Start Injector 1 Malfunction
    P0214 Cold Start Injector 2 Malfunction
    P0215 Engine Shutoff Solenoid Malfunction
    P0216 Injection Timing Control Circuit Malfunction
    P0217 Engine Overtemp Condition
    P0218 Transmission Over Temperature Condition
    P0219 Engine Overspeed Condition
    P0220 Throttle/Petal Position Sensor/Switch B Circuit Malfunction
    P0221 Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
    P0222 Throttle/Petal Position Sensor/Switch B Circuit Low Input
    P0223 Throttle/Petal Position Sensor/Switch B Circuit High Input
    P0224 Throttle/Petal Position Sensor/Switch B Circuit Intermittent
    P0225 Throttle/Petal Position Sensor/Switch C Circuit Malfunction
    P0226 Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
    P0227 Throttle/Petal Position Sensor/Switch C Circuit Low Input
    P0228 Throttle/Petal Position Sensor/Switch C Circuit High Input
    P0229 Throttle/Petal Position Sensor/Switch C Circuit Intermittent
    P0230 Fuel Pump Primary Circuit Malfunction
    P0231 Fuel Pump Secondary Circuit Low
    P0232 Fuel Pump Secondary Circuit High
    P0233 Fuel Pump Secondary Circuit Intermittent
    P0234 Engine Overboost Condition
    P0235 Turbocharger Boost Sensor A Circuit Malfunction
    P0236 Turbocharger Boost Sensor A Circuit Range/Performance
    P0237 Turbocharger Boost Sensor A Circuit Low
    P0238 Turbocharger Boost Sensor A Circuit High
    P0239 Turbocharger Boost Sensor B Malfunction
    P0240 Turbocharger Boost Sensor B Circuit Range/Performance
    P0241 Turbocharger Boost Sensor B Circuit Low
    P0242 Turbocharger Boost Sensor B Circuit High
    P0243 Turbocharger Wastegate Solenoid A Malfunction
    P0244 Turbocharger Wastegate Solenoid A Range/Performance
    P0245 Turbocharger Wastegate Solenoid A Low
    P0246 Turbocharger Wastegate Solenoid A High
    P0247 Turbocharger Wastegate Solenoid B Malfunction
    P0248 Turbocharger Wastegate Solenoid B Range/Performance
    P0249 Turbocharger Wastegate Solenoid B Low
    P0250 Turbocharger Wastegate Solenoid B High
    P0251 Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
    P0252 Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
    P0253 Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
    P0254 Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
    P0255 Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
    P0256 Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
    P0257 Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
    P0258 Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
    P0259 Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
    P0260 Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
    P0261 Cylinder 1 Injector Circuit Low
    P0262 Cylinder 1 Injector Circuit High
    P0263 Cylinder 1 Contribution/Balance Fault
    P0264 Cylinder 2 Injector Circuit Low
    P0265 Cylinder 2 Injector Circuit High
    P0266 Cylinder 2 Contribution/Balance Fault
    P0267 Cylinder 3 Injector Circuit Low
    P0268 Cylinder 3 Injector Circuit High
    P0269 Cylinder 3 Contribution/Balance Fault
    P0270 Cylinder 4 Injector Circuit Low
    P0271 Cylinder 4 Injector Circuit High
    P0272 Cylinder 4 Contribution/Balance Fault
    P0273 Cylinder 5 Injector Circuit Low
    P0274 Cylinder 5 Injector Circuit High
    P0275 Cylinder 5 Contribution/Balance Fault
    P0276 Cylinder 6 Injector Circuit Low
    P0277 Cylinder 6 Injector Circuit High
    P0278 Cylinder 6 Contribution/Balance Fault
    P0279 Cylinder 7 Injector Circuit Low
    P0280 Cylinder 7 Injector Circuit High
    P0281 Cylinder 7 Contribution/Balance Fault
    P0282 Cylinder 8 Injector Circuit Low
    P0283 Cylinder 8 Injector Circuit High
    P0284 Cylinder 8 Contribution/Balance Fault
    P0285 Cylinder 9 Injector Circuit Low
    P0286 Cylinder 9 Injector Circuit High
    P0287 Cylinder 9 Contribution/Balance Fault
    P0288 Cylinder 10 Injector Circuit Low
    P0289 Cylinder 10 Injector Circuit High
    P0290 Cylinder 10 Contribution/Balance Fault
    P0291 Cylinder 11 Injector Circuit Low
    P0292 Cylinder 11 Injector Circuit High
    P0293 Cylinder 11 Contribution/Balance Fault
    P0294 Cylinder 12 Injector Circuit Low
    P0295 Cylinder 12 Injector Circuit High
    P0296 Cylinder 12 Contribution/Range Fault
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Cylinder 1 Misfire Detected
    P0302 Cylinder 2 Misfire Detected
    P0303 Cylinder 3 Misfire Detected
    P0304 Cylinder 4 Misfire Detected
    P0305 Cylinder 5 Misfire Detected
    P0306 Cylinder 6 Misfire Detected
    P0307 Cylinder 7 Misfire Detected
    P0308 Cylinder 8 Misfire Detected
    P0309 Cylinder 9 Misfire Detected
    P0311 Cylinder 11 Misfire Detected
    P0312 Cylinder 12 Misfire Detected
    P0320 Ignition/Distributor Engine Speed Input Circuit Malfunction
    P0321 Ignition/Distributor Engine Speed Input Circuit Range/Performance
    P0322 Ignition/Distributor Engine Speed Input Circuit No Signal
    P0323 Ignition/Distributor Engine Speed Input Circuit Intermittent
    P0325 Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
    P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
    P0327 Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
    P0328 Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
    P0329 Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
    P0330 Knock Sensor 2 Circuit Malfunction (Bank 2)
    P0331 Knock Sensor 2 Circuit Range/Performance (Bank 2)
    P0332 Knock Sensor 2 Circuit Low Input (Bank 2)
    P0333 Knock Sensor 2 Circuit High Input (Bank 2)
    P0334 Knock Sensor 2 Circuit Intermittent (Bank 2)
    P0335 Crankshaft Position Sensor A Circuit Malfunction (L5)
    P0336 Crankshaft Position Sensor A Circuit Range/Performance
    P0337 Crankshaft Position Sensor A Circuit Low Input
    P0338 Crankshaft Position Sensor A Circuit High Input
    P0339 Crankshaft Position Sensor A Circuit Intermittent
    P0340 Camshaft Position Sensor Circuit Malfunction
    P0341 Camshaft Position Sensor Circuit Range/Performance
    P0342 Camshaft Position Sensor Circuit Low Input
    P0343 Camshaft Position Sensor Circuit High Input
    P0344 Camshaft Position Sensor Circuit Intermittent
    P0350 Ignition Coil Primary/Secondary Circuit Malfunction
    P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
    P0352 Ignition Coil B Primary/Secondary Circuit Malfunction
    P0353 Ignition Coil C Primary/Secondary Circuit Malfunction
    P0354 Ignition Coil D Primary/Secondary Circuit Malfunction
    P0355 Ignition Coil E Primary/Secondary Circuit Malfunction
    P0356 Ignition Coil F Primary/Secondary Circuit Malfunction
    P0357 Ignition Coil G Primary/Secondary Circuit Malfunction
    P0358 Ignition Coil H Primary/Secondary Circuit Malfunction
    P0359 Ignition Coil I Primary/Secondary Circuit Malfunction
    P0360 Ignition Coil J Primary/Secondary Circuit Malfunction
    P0361 Ignition Coil K Primary/Secondary Circuit Malfunction
    P0362 Ignition Coil L Primary/Secondary Circuit Malfunction
    P0370 Timing Reference High Resolution Signal A Malfunction
    P0371 Timing Reference High Resolution Signal A Too Many Pulses
    P0372 Timing Reference High Resolution Signal A Too Few Pulses
    P0373 Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
    P0374 Timing Reference High Resolution Signal A No Pulses
    P0375 Timing Reference High Resolution Signal B Malfunction
    P0376 Timing Reference High Resolution Signal B Too Many Pulses
    P0377 Timing Reference High Resolution Signal B Too Few Pulses
    P0378 Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
    P0379 Timing Reference High Resolution Signal B No Pulses
    P0380 Glow Plug/Heater Circuit "A" Malfunction
    P0381 Glow Plug/Heater Indicator Circuit Malfunction
    P0382 Exhaust Gas Recirculation Flow Malfunction
    P0385 Crankshaft Position Sensor B Circuit Malfunction
    P0386 Crankshaft Position Sensor B Circuit Range/Performance
    P0387 Crankshaft Position Sensor B Circuit Low Input
    P0388 Crankshaft Position Sensor B Circuit High Input
    P0389 Crankshaft Position Sensor B Circuit Intermittent
    P0400 Exhaust Gas Recirculation Flow Malfunction
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
    P0402 Exhaust Gas Recirculation Flow Excessive Detected
    P0403 Exhaust Gas Recirculation Circuit Malfunction
    P0404 Exhaust Gas Recirculation Circuit Range/Performance
    P0405 Exhaust Gas Recirculation Sensor A Circuit Low
    P0406 Exhaust Gas Recirculation Sensor A Circuit High
    P0407 Exhaust Gas Recirculation Sensor B Circuit Low
    P0408 Exhaust Gas Recirculation Sensor B Circuit High
    P0410 Secondary Air Injection System Malfunction
    P0411 Secondary Air Injection System Incorrect Flow Detected
    P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
    P0413 Secondary Air Injection System Switching Valve A Circuit Open
    P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
    P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
    P0416 Secondary Air Injection System Switching Valve B Circuit Open
    P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
    P0418 Secondary Air Injection System Relay "A" Circuit Malfunction
    P0419 Secondary Air Injection System Relay "B" Circuit Malfunction
    P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
    P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
    P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
    P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
    P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
    P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
    P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
    P0440 Evaporative Emission Control System Malfunction
    P0441 Evaporative Emission Control System Incorrect Purge Flow
    P0442 Evaporative Emission Control System Leak Detected (small leak)
    P0443 Evaporative Emission Control System Purge Control Valve Circuit Malfunction
    P0444 Evaporative Emission Control System Purge Control Valve Circuit Open
    P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
    P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
    P0447 Evaporative Emission Control System Vent Control Circuit Open
    P0448 Evaporative Emission Control System Vent Control Circuit Shorted
    P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
    P0450 Evaporative Emission Control System Pressure Sensor Malfunction
    P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
    P0452 Evaporative Emission Control System Pressure Sensor Low Input
    P0453 Evaporative Emission Control System Pressure Sensor High Input
    P0454 Evaporative Emission Control System Pressure Sensor Intermittent
    P0455 Evaporative Emission Control System Leak Detected (gross leak)
    P0460 Fuel Level Sensor Circuit Malfunction
    P0461 Fuel Level Sensor Circuit Range/Performance
    P0462 Fuel Level Sensor Circuit Low Input
    P0463 Fuel Level Sensor Circuit High Input
    P0464 Fuel Level Sensor Circuit Intermittent
    P0465 Purge Flow Sensor Circuit Malfunction
    P0466 Purge Flow Sensor Circuit Range/Performance
    P0467 Purge Flow Sensor Circuit Low Input
    P0468 Purge Flow Sensor Circuit High Input
    P0469 Purge Flow Sensor Circuit Intermittent
    P0470 Exhaust Pressure Sensor Malfunction
    P0471 Exhaust Pressure Sensor Range/Performance
    P0472 Exhaust Pressure Sensor Low
    P0473 Exhaust Pressure Sensor High
    P0474 Exhaust Pressure Sensor Intermittent
    P0475 Exhaust Pressure Control Valve Malfunction
    P0476 Exhaust Pressure Control Valve Range/Performance
    P0477 Exhaust Pressure Control Valve Low
    P0478 Exhaust Pressure Control Valve High
    P0479 Exhaust Pressure Control Valve Intermittent
    P0480 Cooling Fan 1 Control Circuit Malfunction
    P0481 Cooling Fan 2 Control Circuit Malfunction
    P0482 Cooling Fan 3 Control Circuit Malfunction
    P0483 Cooling Fan Rationality Check Malfunction
    P0484 Cooling Fan Circuit Over Current
    P0485 Cooling Fan Power/Ground Circuit Malfunction
    P0500 Vehicle Speed Sensor Malfunction
    P0501 Vehicle Speed Sensor Range/Performance
    P0502 Vehicle Speed Sensor Low Input
    P0503 Vehicle Speed Sensor Intermittent/Erratic/High
    P0505 Idle Control System Malfunction
    P0506 Idle Control System RPM Lower Than Expected
    P0507 Idle Control System RPM Higher Than Expected
    P0510 Closed Throttle Position Switch Malfunction
    P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
    P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
    P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
    P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
    P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction
    P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance
    P0532 A/C Refrigerant Pressure Sensor Circuit Low Input
    P0533 A/C Refrigerant Pressure Sensor Circuit High Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0550 Power Steering Pressure Sensor Circuit Malfunction
    P0551 Power Steering Pressure Sensor Circuit Range/Performance
    P0552 Power Steering Pressure Sensor Circuit Low Input
    P0553 Power Steering Pressure Sensor Circuit High Input
    P0554 Power Steering Pressure Sensor Circuit Intermittent
    P0560 System Voltage Malfunction
    P0561 System Voltage Unstable
    P0562 System Voltage Low
    P0563 System Voltage High
    P0565 Cruise Control On Signal Malfunction
    P0566 Cruise Control Off Signal Malfunction
    P0567 Cruise Control Resume Signal Malfunction
    P0568 Cruise Control Set Signal Malfunction
    P0569 Cruise Control Coast Signal Malfunction
    P0570 Cruise Control Accel Signal Malfunction
    P0571 Cruise Control/Brake Switch A Circuit Malfunction
    P0572 Cruise Control/Brake Switch A Circuit Low
    P0573 Cruise Control/Brake Switch A Circuit High
    P0574 Cruise Control Related Malfunction
    P0575 Cruise Control Related Malfunction
    P0576 Cruise Control Related Malfunction
    P0578 Cruise Control Related Malfunction
    P0579 Cruise Control Related Malfunction
    P0580 Cruise Control Related Malfunction
    P0600 Serial Communication Link Malfunction
    P0601 Internal Control Module Memory Check Sum Error
    P0602 Control Module Programming Error
    P0603 Internal Control Module Keep Alive Memory (KAM) Error
    P0604 Internal Control Module Random Access Memory (RAM) Error
    P0605 Internal Control Module Read Only Memory (ROM) Error
    P0606 PCM Processor Fault
    P0608 Control Module VSS Output "A" Malfunction
    P0609 Control Module VSS Output "B" Malfunction
    P0620 Generator Control Circuit Malfunction
    P0621 Generator Lamp "L" Control Circuit Malfunction
    P0622 Generator Field "F" Control Circuit Malfunction
    P0650 Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
    P0654 Engine RPM Output Circuit Malfunction
    P0655 Engine Hot Lamp Output Control Circuit Malfucntion
    P0656 Fuel Level Output Circuit Malfunction
    P0700 Transmission Control System Malfunction
    P0701 Transmission Control System Range/Performance
    P0702 Transmission Control System Electrical
    P0703 Torque Converter/Brake Switch B Circuit Malfunction
    P0704 Clutch Switch Input Circuit Malfunction
    P0705 Transmission Range Sensor Circuit malfunction (PRNDL Input)
    P0706 Transmission Range Sensor Circuit Range/Performance
    P0707 Transmission Range Sensor Circuit Low Input
    P0708 Transmission Range Sensor Circuit High Input
    P0709 Transmission Range Sensor Circuit Intermittent
    P0710 Transmission Fluid Temperature Sensor Circuit Malfunction
    P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance
    P0712 Transmission Fluid Temperature Sensor Circuit Low Input
    P0713 Transmission Fluid Temperature Sensor Circuit High Input
    P0714 Transmission Fluid Temperature Sensor Circuit Intermittent
    P0715 Input/Turbine Speed Sensor Circuit Malfunction
    P0716 Input/Turbine Speed Sensor Circuit Range/Performance
    P0717 Input/Turbine Speed Sensor Circuit No Signal
    P0718 Input/Turbine Speed Sensor Circuit Intermittent
    P0719 Torque Converter/Brake Switch B Circuit Low
    P0720 Output Speed Sensor Circuit Malfunction
    P0721 Output Speed Sensor Range/Performance
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Intermittent
    P0724 Torque Converter/Brake Switch B Circuit High
    P0725 Engine Speed input Circuit Malfunction
    P0726 Engine Speed Input Circuit Range/Performance
    P0727 Engine Speed Input Circuit No Signal
    P0728 Engine Speed Input Circuit Intermittent
    P0730 Incorrect Gear Ratio
    P0731 Gear 1 Incorrect ratio
    P0732 Gear 2 Incorrect ratio
    P0733 Gear 3 Incorrect ratio
    P0734 Gear 4 Incorrect ratio
    P0735 Gear 5 Incorrect ratio
    P0736 Reverse incorrect gear ratio
    P0740 Torque Converter Clutch Circuit Malfuction
    P0741 Torque Converter Clutch Circuit Performance or Stuck Off
    P0742 Torque Converter Clutch Circuit Stuck On
    P0743 Torque Converter Clutch Circuit Electrical
    P0744 Torque Converter Clutch Circuit Intermittent
    P0745 Pressure Control Solenoid Malfunction
    P0746 Pressure Control Solenoid Performance or Stuck Off
    P0747 Pressure Control Solenoid Stuck On
    P0748 Pressure Control Solenoid Electrical
    P0749 Pressure Control Solenoid Intermittent
    P0750 Shift Solenoid A Malfunction
    P0751 Shift Solenoid A Performance or Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Intermittent
    P0755 Shift Solenoid B Malfunction
    P0756 Shift Solenoid B Performance or Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Intermittent
    P0760 Shift Solenoid C Malfunction
    P0761 Shift Solenoid C Performance or Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Intermittent
    P0765 Shift Solenoid D Malfunction
    P0766 Shift Solenoid D Performance or Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Intermittent
    P0770 Shift Solenoid E Malfunction
    P0771 Shift Solenoid E Performance or Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Intermittent
    P0780 Shift Malfunction
    P0781 1-2 Shift Malfunction
    P0782 2-3 Shift Malfunction
    P0783 3-4 Shift Malfunction
    P0784 4-5 Shift Malfunction
    P0785 Shift/Timing Solenoid Malfunction
    P0786 Shift/Timing Solenoid Range/Performance
    P0787 Shift/Timing Solenoid Low
    P0788 Shift/Timing Solenoid High
    P0789 Shift/Timing Solenoid Intermittent
    P0790 Normal/Performance Switch Circuit Malfunction
    P0801 Reverse Inhibit Control Circuit Malfunction
    P0803 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
    P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
    P0805 Clutch Position Sensor Circuit Malfunction
    P0806 Clutch Position Sensor Circuit Range/Performance
    P0807 Clutch Position Sensor Circuit Low
    P0808 Clutch Position Sensor Circuit High
    P0809 Clutch Position Sensor Circuit Intermittent Ckt
    P0810 Clutch Position Control Malfunction
    P0811 Clutch Slippage Excessive
    P0812 Reverse Input Circuit Malfunction
    P0813 Reverse Output Circuit Malfunction
    P0814 Trans Range Display Circuit Malfunction
    P0815 Upshift Switch Circuit Malfunction
    P0816 Downshift Switch Circuit Malfunction
    P0817 Starter Disable Circuit
    P0818 Driveline Disconn. Switch Input
    P0820 Gear Lever X-Y Sensor Circuit
    P0821 Gear Lever X Sensor Circuit
    P0822 Gear Lever Y Sensor Circuit
    P0823 Gear Lever X Sensor Circuit Intermittent Ckt
    P0824 Gear Lever Y Sensor Circuit Intermittent Ckt
    P0830 Clutch Position Switch A Circuit Malfunction
    P0831 Clutch Position Switch A Circuit Low
    P0832 Clutch Position Switch A Circuit High
    P0833 Clutch Position Switch B Circuit Malfunction
    P0834 Clutch Position Switch B Circuit Low
    P0835 Clutch Position Switch B Circuit High
    P0836 4 Wheel Drive Switch Circuit Malfunction
    P0837 4 Wheel Drive Switch CKT Range/Perf
    P0838 4 Wheel Drive Switch Circuit Low
    P0839 4 Wheel Drive Switch Circuit High
    P0840 Trans Fluid Press Sensor/Switch A Circuit Malfunction
    P0841 Trans Fluid Press Sensor/Switch A CKT Range/Perf
    P0842 Trans Fluid Press Sensor/Switch A Circuit Low
    P0843 Trans Fluid Press Sensor/Switch A Circuit High
    P0844 Trans Fluid Press Sensor/Switch A CKT Intermittent
    P0845 Trans Fluid Press Sensor/Switch B Circuit Malfunction
    P0846 Trans Fluid Press Sensor/Switch B CKT Range/Perf
    P0847 Trans Fluid Press Sensor/Switch B Circuit Low
    P0848 Trans Fluid Press Sensor/Switch B Circuit High
    P0849 Trans Fluid Press Sensor/Switch B CKT Intermittent
    P1000 Electronic Gear Selector Module: Defective N15/5
    P1570 Intermittant No-Start Immobiliser Module
    P1581 ?
    P1747 Electronic Gear Selector Module: Defective Interaction of CAN with control unit A1(instrument cluster)
    P1750 Electronic Gear Selector Module: Very low control unit supply voltage
    P1832 Electronic Gear Selector Module: SHORT in circuit N15/5 output stage
    P1910 Electronic Gear Selector Module: Control Unit over voltage
    P1912 Electronic Gear Selector Module: Weak touch push button voltage
    P2000 NOx Trap Efficiency Below Threshold (Bank 1)
    P2001 NOx Trap Efficiency Below Threshold (Bank 2)
    P2003 Particulate Trap Efficiency Below Threshold (Bank 1)
    P2004 Particulate Trap Efficiency Below Threshold (Bank 2)
    P2031 Exhaust Gas Temperature Sensor Circuit (Bank 1 Sensor 2)
    P2032 Exhaust Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2)
    P2033 Exhaust Gas Temperature Sensor Circuit High (Bank 1 Sensor 2)
    P2080 Exhaust Gas Temperature Sensor Circuit Range/Performance (Bank 1 Sensor 1)
    P2081 Exhaust Gas Temperature Sensor Circuit intermittant (Bank 1 Sensor 1)
    P2100 Throttle Actuator Control Motor Circuit/Open
    P2101 Throttle Actuator Control Motor Circuit Range/Performance
    P2208 transmission: The speed of Y3/6n2 to Y3/6n3 is excessive
    Body
    B1000 HRA Headlamp range adjustment: Supply voltage of the control unit is too low (undervoltage)
    B1004 LCP Lower Control Panel: Control unit does not match vehicle type
    B1056 Automatic Air Conditioning: Problem in CAN communication with control unit DCM-RL
    B1201 Electric seat adjustment front left: Hall sensor front height M27m3
    B1213 If seat memory installed: ext left rearview mirror voltage faulty
    B1214 If seat memory installed: ext right rearview mirror voltage faulty
    B1226 In-car temperature sensor (B10/4)
    B1227 Outside temperature indicator temp sensor (014)
    B1128 Heater core temperature (B10/1)
    B1229 Heater core temperature (B10/1)
    B1230 Evaporator temperature sensor (B10/6)
    B1231 ECT sensor (B11/4)
    B1232 Refrigerant pressure sensor (B12)
    B1233 Refrigerant temperature sensor (B12/1)
    B1234 Sun sensor (B32)
    B1235 Emissions sensor (B31)
    B1241 Refrigerant Fill
    B1246 PTS Parktronic: A42b1 (left outer sensor, front bumper) The plug connection has poor contact or is loose, or the sensor or cable is faulty
    B1310 Left/Window airbag sensor is defective
    B1315 Problem in Front passenger child seat recognition
    B1416 Coolant circulation pump (M13)
    B1417 Duovalve (Y21y1), left
    B1418 Duovalve (Y21y2), right
    B1419 Electromagnetic clutch (A9k1)
    B1420 Idle speed increase
    B1421 Pulse module (N05)
    B1422 Series interface (K1) connection to instrument cluster (A1)
    B1423 Switchover valve block (Y11)
    B1424 Activated charcoal filler actuator (A32m2) open
    B1425 Activated charcoal filler actuator (A32m2) closed
    B1432 Non-USA DTC
    B1459 Series interface (K2) connection to instrument cluster (A1)
    B1462 Wide open throttle (WOT) position signal diesel engines
    B1476 Airbag malfunction indicator and warning lamp is defective
    B1481 HRA: Part E2m1 (Right headlamp range adjustment motor) has short to ground
    B1489 HRA: Part E2m1 (Right headlamp range adjustment motor) has open or short to positive
    B1492 HRA: Part E1m1 (Left headlamp range adjustement motor) has short to positive
    B1617 Part E19/1 (Left license plate lamp) is defective
    B1618 Part E19/2 (Right license plate lamp) is defective
    B1628 Part E2e5 (Turn signal lamp) in module E2 (Right front headlamp unit) is defective.
    B1703 Intermittant No Start in AAM Immobiliser Module
    B1729 PSE Pneumatic system doorlock Control Module A37
    B1736 Navigation system's CD Player: Check General CD, Check CD data block, Flimsy CD data
    B1768 Faulty open data flap limit switch (0025) Front flap
    B1773 HRA: Zero position programming has not yet been carried out or is not possible
    B1850 Electric seat adjustment front right: CAN communication interrupted with DCM
    Chassis
    C1000 Traction System Control Module
    C1010 Battery Voltage Low
    C1011 ASR/ETS/ESP Circuit Open or Shorted
    C1012 Battery Voltage High
    C1020 CAN Communication Fault
    C1021 CAN Communication With EA/CC/ISC Control Module Interrupted
    C1024 CAN Communication With Engine Control Module Interrupted
    C1025 CAN Communication BAS communication with ESP control unit faulty
    C1100 Left Front Axle VSS Circuit Fault
    C1101 Right Front Axle VSS Circuit Fault
    C1102 ETS/ASR, ABS Left Axle VSS Circuit Fault
    C1103 Right Rear Axle VSS Circuit Fault
    C1121 AIRmatic: fault in component B24/3 (acceler. sensor)
    C1122 AIRmatic: fault in component B24/4 (acceler. sensor)
    C1123 AIRmatic: fault in component B24/6 (acceler. sensor)
    C1132 AIRmatic: fault in component B22/8 (level sensor)
    C1133 AIRmatic: fault in component B22/9 (level sensor)
    C1135 AIRmatic: fault in component B22/3 (level sensor)
    C1140 BAS light, play in steering column causes steering angle sensor to lose memory(?)
    C1142 ABS Lateral Acceleration Sensor Open/Shorted
    C1144 AIRmatic: fault in component B7 (pressure sensor)
    C1200 Stop Light Switch Open/Shorted/Implausible
    C1300 Left Front Axle Solenoid Valve (Hold) (A7/3y6) Open/Shorted
    C1303 Right Front Axle Solenoid Valve (Hold) Open/Shorted
    C1311 Switchover Solenoid Valve (Release) Open/Shorted
    C1312 Master Cylinder Switchover Valve
    C1401 High Pressure Return Pump Circuit Open/Shorted; Will Not Shut Off
    C1501 SPS P-Valve
    C1504 BAS light, play in steering column causes steering angle sensor to lose memory(?)
    C1512 Brakes Overheated
    C1600 Temperature After Engine Is Turned Off
    New Systems
    U0001 High Speed CAN Communication Bus
    U0002 High Speed CAN Communication Bus Performance
    U0003 High Speed CAN Communication Bus (+) open
    U0004 High Speed CAN Communication Bus (+) low
    U0005 High Speed CAN Communication Bus (+) high
    U0006 High Speed CAN Communication Bus (-) open
    U0007 High Speed CAN Communication Bus (-) low
    U0008 High Speed CAN Communication Bus (-) high
    U0009 High Speed CAN Communication Bus (-) shorted to Bus (+)
    U0010 Medium Speed CAN Communication Bus
    U0011 Medium Speed CAN Communication Bus Performance
    U0012 Medium Speed CAN Communication Bus (+) open
    U0013 Medium Speed CAN Communication Bus (+) low
    U0014 Medium Speed CAN Communication Bus (+) high
    U0015 Medium Speed CAN Communication Bus (-) open
    U0016 Medium Speed CAN Communication Bus (-) low
    U0017 Medium Speed CAN Communication Bus (-) high
    U0018 Medium Speed CAN Communication Bus (-) shorted to Bus (+)
    U0019 Low Speed CAN Communication Bus
    U0020 Low Speed CAN Communication Bus Performance
    U0021 Low Speed CAN Communication Bus (+) open
    U0022 Low Speed CAN Communication Bus (+) low
    U0023 Low Speed CAN Communication Bus (+) high
    U0024 Low Speed CAN Communication Bus (-) open
    U0025 Low Speed CAN Communication Bus (-) low
    U0026 Low Speed CAN Communication Bus (-) high
    U0027 Low Speed CAN Communication Bus (-) shorted to Bus (+)
    U0028 Vehicle Communication Bus A
    U0029 Vehicle Communication Bus A Performance
    U0030 Vehicle Communication Bus A (+) open
    U0031 Vehicle Communication Bus A (+) low
    U0032 Vehicle Communication Bus A (+) high
    U0033 Vehicle Communication Bus A (-) open
    U0034 Vehicle Communication Bus A (-) low
    U0035 Vehicle Communication Bus A (-) high
    U0036 Vehicle Communication Bus A (-) shorted to Bus (+)
    U0037 Vehicle Communication Bus B
    U0038 Vehicle Communication Bus B Performance
    U0039 Vehicle Communication Bus B (+) open
    U0040 Vehicle Communication Bus B (+) low
    U0041 Vehicle Communication Bus B (+) high
    U0042 Vehicle Communication Bus B (-) open
    U0043 Vehicle Communication Bus B (-) low
    U0044 Vehicle Communication Bus B (-) high
    U0045 Vehicle Communication Bus B (-) shorted to Bus (+)
    U0046 Vehicle Communication Bus C
    U0047 Vehicle Communication Bus C Performance
    U0048 Vehicle Communication Bus C (+) open
    U0049 Vehicle Communication Bus C (+) low
    U0050 Vehicle Communication Bus C (+) high
    U0051 Vehicle Communication Bus C (-) open
    U0052 Vehicle Communication Bus C (-) low
    U0053 Vehicle Communication Bus C (-) high
    U0054 Vehicle Communication Bus C (-) shorted to Bus (+)
    U0055 Vehicle Communication Bus D
    U0056 Vehicle Communication Bus D Performance
    U0057 Vehicle Communication Bus D (+) open
    U0058 Vehicle Communication Bus D (+) low
    U0059 Vehicle Communication Bus D (+) high
    U0060 Vehicle Communication Bus D (-) open
    U0061 Vehicle Communication Bus D (-) low
    U0062 Vehicle Communication Bus D (-) high
    U0063 Vehicle Communication Bus D (-) shorted to Bus (+)
    U0064 Vehicle Communication Bus E
    U0065 Vehicle Communication Bus E Performance
    U0066 Vehicle Communication Bus E (+) open
    U0067 Vehicle Communication Bus E (+) low
    U0068 Vehicle Communication Bus E (+) high
    U0069 Vehicle Communication Bus E (-) open
    U0070 Vehicle Communication Bus E (-) low
    U0071 Vehicle Communication Bus E (-) high
    U0072 Vehicle Communication Bus E (-) shorted to Bus (+)
    U0073 Control Module Communications Bus Off
    U0100 Lost Communication with ECM/PCM A
    U0101 Lost Communication with TCM
    U0102 Lost Communication with Transfer Case Control Module
    U0103 Lost Communication with Gear Shift Module
    U0104 Lost Communication with Cruise Control Module
    U0105 Lost Communication with Fuel Injector Control Module
    U0192 Lost Communication with Television
    U0197 Lost Communication with Telephone Control Module
    U0198 Lost Communication with Telematic Control Module
    U0222 Lost Communication with Door Window Motor A
    U0235 Lost Communications with Cruise Control Front Distance Range Sensor
    U0301 Software Incompatibility with ECM/PCM
    U0302 Software Incompatibility with TCM (Transmission Control Module)
    U0303 Software Incompatibility with Transfer Case Control Module
    U0321 Software Incompatibility with Ride Level Control Module
    U0326 Software Incompatibility with Vehicle Immobilizer Control Module
    U0327 Software Incompatibility with Vehicle Security Control Module
    LINK: www.whnet.com/4x4/diagnostic.html
    1 person likes this.
  2. Dave K
    Dave K Hardcore MB Enthusiast
    155
    Sep 16, 2002
    East Sussex
    Car:
    E320 CDi (W210)
    Must have taken you ages to type that lot in :p
  3. Paul
    Paul Hardcore MB Enthusiast
    488
    Jul 7, 2002
    Lordswood, Kent.
    Car:
    Ford 2.3 Galaxy
    Phew!!:crazy: :D
  4. Merc600SEC
    Merc600SEC New Member
    18
    Jul 8, 2004
    Leicester UK
    Car:
    Merc 600 V12 Coupe
    Thats OK for OBD2 stuff What about OBD1 as fitted to my 1994 V12 S600 Coupe??
  5. guydewdney
    guydewdney Hardcore MB Enthusiast
    2,903
    Feb 14, 2004
    Porlock, Zomerzet
    Car:
    906 Sprinter 313cdi
    yours is analogue - have a look at JimF's site - try s500 coupe diagnostic or coolharness in google for him / his site..
    for anyone interested / near me - i have the laptop and diagnostic plug for OBDII up and working now (and i can do dyno runs :D )
  6. GSMGuy
    GSMGuy Hardcore MB Enthusiast
    202
    Oct 23, 2005
    St Helens, Merseyside
    Car:
    Volvo XC90 D5 SE
    Nice post... Just out of interest, what's the best diag kit to buy for use with my lappy... Las car I had (Galaxy) I got VAG-COM genuine interface which was very giid..
    Mike
  7. Amethyst
    Amethyst New Member
    2
    Sep 6, 2008
    Sos! Slk Cel, Po150
    I'm new to this forum and couldn''t find how to start a new thread, so I'm trying this.
    My 1999 SLK230's CEL came on at 80K+miles and the diagnostic code was PO170. The independent mechanic gave me a new sensor. The light came back on within a few days. The code now reads PO150. He said there's no such code, although something is wrong since the CEL won't stay off for longer than a couple of days. His diagnostics thingie actually showed many codes, including clutch problems and he checked all of those. Still nothing. :( My little handheld diagnostics tool consistently shows PO150. Has anyone else had this experience and found a solution?
  8. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,087
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, MK1 Caddy, S500, etc
    Throw away your tool first. It wont give you all the codes.
    Take the codes at face value and use them as a guide. You have other issues I suspect causing O2 sensor fault. I would get it on a Star machine first (MB diagnostics). People like me and Jaymanek have them.
  9. Amethyst
    Amethyst New Member
    2
    Sep 6, 2008
    Sos! Slk Cel, Po150
    Wow... a reply already. Thank you! My borrowed toy toy was simply to switch off the CEL. (I'm due for a VEIP check and can't pass it with that on, and can't get it immediately after turning off the light.) The mechanic is/was MB certified (many in the local MB club goes to him) and has up-to-date Star tools. That's where the multiple codes came up and why he checked the clutch and a host of other things. He and his buddies at the dealership agree that it can't be all of those codes at once if nothing checked out as broken. However, the dealership mechanics suggested that it "could be a wire under the harness." I''m trying to avoid going to the despised dealership although they have very good coffee there and the loaners are fun to drive.
  10. BlackC55
    18,087
    Feb 8, 2007
    Car:
    They will need to read the fresh codes and look at some values to decipher them.
  11. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    Crikey. That's a big word on a Saturday night when you're half cut..:D
  12. BlackC55
    18,087
    Feb 8, 2007
    Car:
    Oi Im not ****** or even half cut. Just opened my 3rd can of 6X.
  13. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    I meant me...:D
  14. BlackC55
    18,087
    Feb 8, 2007
    Car:
    Oh I see. :)
    I wanted to go down the pub tonight. But the boss gave me the "look"
  15. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Has that horse box got a lock on it..
  16. rlowy
    rlowy Hardcore MB Enthusiast
    291
    Apr 14, 2007
    Surrey
    Car:
    W212 E63
    Can you see these codes in Comand on a 54 plate E211?
  17. BlackC55
    18,087
    Feb 8, 2007
    Car:
    With a Star machine, yes.
  18. solarmer1
    solarmer1 Active Member
    80
    Jan 11, 2009
    Car:
    MB 2001 E320cdi, 2010 W212 E350
    W210 year 2001. E320CDI. Is it OBD2?
    Hi.
    I' m searching for a diagnostic tool. Can anyone tell me if my car is OBD2?
    The 38 pin socket is in the fuse box in the engine compartment.
    Thank you.
    regards
    Ken
  19. CKLclive
    CKLclive Banned
    907
    Nov 5, 2008
    Car:
    CLK 430
    Ha ha oily Know how you feeling I get the same The LOOK :(
  20. solarmer1
    80
    Jan 11, 2009
    Car:
    Hi.
    I believe i can answer my own question. Just taken a look at Wikipaedia which gives excellent coverage and definition of OBD.
    It appears that OBD2 must have the connector within 2 feet of the driver hence mine is not OBD2.
    I still need diagnostic tool howevermand any advice will be much appreciated.
    Thank you.
    Regards
    Solarmer
Share This Page
