grzegorz2200
- Dec 16, 2011
- mercedes ml 320cdi
Sounds like you've missed something when you've put it back together. I don't think there will be too many on here that will have delved into the steering column shroud of a 205....Hello, steering wheel cover do not work ,steering wheel buttons, wiper knob,gears knob,horn, all fuses is ok, I bought a new housing and without changes, but when disconnect housing on running engine engine stopped working. Please help
hey buddy were exactly was the cut wire? have the same problemHello, steering wheel cover do not work ,steering wheel buttons, wiper knob,gears knob,horn, all fuses is ok, I bought a new housing and without changes, but when disconnect housing on running engine engine stopped working. Please help
Can you tell which wire was damaged? Maybe someone else has solved the problem?Hi,I find problem power steering wire was snapped.Thank you any way
