Mercedes diagnostic recommendations
blitz500sl
Basildon, Essex
92' R129 500SL - 04' E500 Estate - 09' Smart 451 CDI
I need some Mercedes specific diagnostic now to access all the Mercedes modules. Star is way to expensive.
Has anyone used Carly Mercedes or iCarsoft MB-II
thanks
Yes, about a million people have tried icarsoft. If you go to benzworld's w220 forum, a guy posted a pretty detailed review of it.
I have a icarsoft II that could be for sale
I have MB iCarsoft II. For the price its excellent. Easy to use and the database of DTC codes can be upgraded free on line and saved to the unit via the supplied micro card USB stick (PC/MAC required).
I have Icarsoft MB2. It has successfully diagnosed 2 faults on our ML270, ABS fault and Parktronic fault. It also diagnosed s temperature sensor fault on our Mini cooper.
For the money, excellent but not a star tool.
I ran the freebie diagnostic with Carly and my £5 bluetooth ODB lump and was very impressed with the results, it told me exactly what was causing my intermittent ESP error, SAS rather than brake light switch unfortunately but could've been worse, and exactly which parking sensor mucks about sometimes. If anyone's interested this is the report I got...
Fault Report - Carly for Mercedes - Version: 11.30 LV
ID1: 5102f130-0c29-4e64-8dad-4c2996f0fe18-86auID2: e23e5c1b-12e4-4567-b0e4-a8ef9208fb85-da0-5b45bc066aa8fa32
INFO: 0D01E7D6C5C1A49A847A655545355
Base: CLS Coupe - 219/ CLS Coupe - 219
Build-Year: 2005
Faults: 16
ECUs: 30
Filter: just found
Model: CLS Coupe - 219 all/alle (MotorID=null, Parameter=0)
Battery: 11.4V
ADDITIONAL OBD: OFF
Enhanced communication
Normal connection
Optimized: 100
None
Date: 2017-12-05 20:34:04
OBDII
Version: 27
Device: >LGE< >bullhead< >Nexus 5X<
Motor Control:
FSCU - Fuel pump (MB: NO_HWID_FOUND)
ECU not present/no response from ECU
Motor Electronics (MB: NO_HWID_FOUND)
ECU OK, no Fault or Event Code
ABS / DSC / Brake:
DTR - Distronic (MB: NO_HWID_FOUND)
WSS - Weight sensing system (MB: NO_HWID_FOUND)
Airbag:
AB - Airbag (MB: 8076857519)
Transmission Control:
ESM - Electronic selector module (MB: 5542327401)
ETC - Electronic transmission control (MB: 0345451532)
Instrument cluster:
OCP - Overhead control panel (MB: 8091731552)
Fault: Component E15/3b2 (Interior protection sensor) signals an internal error. Component N70/2b1 (Interior protection sensor) signals an internal error.
Code: 0090A4
IC - Instrument cluster (MB: 5071553510)
UCP - Upper control panel (MB: 8158048470)
Fault: Not Relevant! / Fault: Fault in CAN communication with control unit N62 (PTS control unit). / Fault: No CAN message was received from control unit N93 (Central gateway control unit).
Code: 009028
LCP - Lower control panel (MB: 8108038370)
Light/Rain Control:
HRA - Headlamp range adjustment (MB: 8016330452)
Fault: No CAN message 'Steering angle' from control unit N80 (Steering column module). Not Relevant!
Code: 009035
Heating / AC:
AAC - Automatic air conditioning (MB: 8065148514)
Fault: Not Relevant! A32n1 (Blower regulator) If no customer complaint exists, the fault can be erased. / Fault: Electrical fault A32n1 (Blower regulator) If no customer complaint exists, the fault can be erased.
Code: 009460
STH - Stationary heater with remote control (MB: NO_HWID_FOUND)
Immobilizer System:
ASSYST Active Service System (MB: 5075942311)
ASSYST PLUS - PLUS Active Service System (MB: 5075942311)
Park distance control:
PTS - Parktronic system (MB: 5532447431)
Code: 009091
Fault: A42b2 (Left center sensor, front bumper) : Sensor is faulty. / Fault: Fault in communication with component B8/1 (Outer left front PTS ultrasonic sensor).
Code: 009004
Audio/Navi/Communication:
DAB - Digital radio (MB: 8059757611)
Sorry, there is no explanation available
Code: 00D010
Code: 00D001
COMAND or AUDIO (MB: NO_HWID_FOUND)
SOUND - Sound system (MB: 8079650613)
TV - TV tuner (MB: 0000000000)
UCI - Media Interface (MB: NO_HWID_FOUND)
AGW - Audio gateway (MOST network management, diagnosis gateway, radio tuner) (MB: 8792331516)
Fault: Rated - Current configuration of the MOST-optical ring is different
Code: 00D117
TELE AID - Telematic service Emergency call (MB: NO_HWID_FOUND)
TELE AID - Telematic services Remote door unlocking , Remote door locking (MB: NO_HWID_FOUND)
TELE AID - Telematic services MB Info , Roadside assistance ( USA, Canada ), Tele diagnosis ( ECE ) (MB: NO_HWID_FOUND)
TELE AID - Telematic service Stolen vehicle tracking (MB: NO_HWID_FOUND)
Systems:
LAE [LAA] - Loading floor automatically extendable (MB: NO_HWID_FOUND)
EZS - Electronic ignition switch (MB: NO_HWID_FOUND)
SCM [MRM] - Steering column module (MB: 5592157370)
Fault: Component N49 (Steering angle sensor) is defective. / Fault: Component N49 (Steering angle sensor) is defective. Component B24/8 (Steering angle sensor) is defective.
Code: 009334
Fault: Steering angle sensor speed too high
Code: 009352
TPC - Tire pressure monitor (MB: NO_HWID_FOUND)
Pass-side SAM - Passenger-side signal acquisition and actuation module (MB: 5552550410)
REAR SAM - Rear signal acquisition and actuation module (MB: 5571250452)
Dr-side SAM - Driver signal acquisition and actuation module (MB: 5541240410)
ESP - Electronic stability program (MB: 2115454832)
Code: 006230
Code: 006210
Fault: Fault in CAN communication with control unit N93 (Central gateway control unit). Check control unit N47-5 (ESP, SPS [PML] and BAS control unit).
Code: 005B15
Fault: DTR : The CAN communication of the engine control module is faulty. / Fault: LRG1: ID608 V_Max_Fix out of range
Code: 007211
Fault: Check component N49 (Steering angle sensor). / Fault: One or more signals sent from control unit N80 (Steering column module) via the CAN bus is implausible.
Code: 004D41
AIRmatic (MB: 5522649515)
GPS box (MB: NO_HWID_FOUND)
CGW - Central gateway (MB: 5075942311)
Body:
DS-LF - Left front dynamic seat (MB: NO_HWID_FOUND)
DS-RF - Right front dynamic seat (MB: NO_HWID_FOUND)
DSP - Pneumatic pump for dynamic seat (MB: NO_HWID_FOUND)
RevETR-LF - Left front reversible emergency tensioning retractor (MB: NO_HWID_FOUND)
RevETR-RF - Right front reversible emergency tensioning retractor (MB: NO_HWID_FOUND)
HS - Seat heater (MB: NO_HWID_FOUND)
ESA passenger - Electric seat adjustment front passenger (with memory) (MB: 2118705026)
ESA driver - Electric seat adjustment driver (with memory) (MB: 2118704926)
DCM-RL - Door control module rear left (MB: 8026340411)
DCM-RR - Door control module rear right (MB: 8036340411)
DCM-FL - Door control module front left (MB: 8066540411)
DCM-FR - Door control module front right (MB: 8076540411)
I have Carly MB, it’s OK not mega polished but does get a lot of MB specific and detailed codes out. Its a code reader basically but goes way beyond what you get from an OBD2 one.
It’s not as good as the Carly BMW app though - they get to do coding and all sorts with theirs!
just to update, MB2 just successfully diagnosed a Parktronic issue as one sensor faulty, so works on that system as well. If you consider that i have used it 4 times now and been successful, if you translate that into MB charges for diagnostic then at £150 it has more than paid for itself.
I have the full Carly Pro app including the Carly adapter, and yes the interface is a bit quirky, and some 'faults' detected seem sporadic, but all in all it work well for the money.
The big plus is that I leave the adapter permanently connected to the OBDII port so I can hop on at any time from my mobile phone without having to fumble with cables etc (which I had to do with my old Autel).
Ive got mb2 @ £136 its reset my aircon following a regas. Its told me my inboard air temp sensor has failed. Ill be using it to disable sbc come brake pad changes. Very good bit of kit.
Impressed with the iCarsoft MB reader, five minutes practice and you're profficient, finds and clears faults quickly on all systems, not just engine, just under £100, one scan pays for it. I've also got one for my Wife's Renault, and another for a previously owned Jaguar. More than worth the cost.
I'm looking at getting either the Carsoft i980or the more up to date MB II reader to use on my '07 W203 C230.
There seems to be about £35-£40 difference in price between the two, so any advice please from those of you who already use these on whether the later one is worth paying the extra for?
BUY THE MB2 FOR £136 , it covers alot more modules than the i980 also you get updates via icarsoft website.
OK, fair enough. Thanks.
Could anyone please tell me whether the icarsoft MB II would be compatiable with my 2015 CLA 220 Shooting Brake as when I look at the models listed I can’t see mine there.
I have just upgraded my MB Star C4 with an SSD to replace the HD in the Panasonic toughbook. Makes it a lot quicker to load the software, well worth the cost and effort.
