Stardelta
Just been to pick the wife up, pulled up to let her in and the brake pedal sunk lower than usual, proceeded to drive home and decided to pull over to check fluid level, it was 10mm below the high mark, drove the rest of the journey, luckily only a few minutes up the road, when home rechecked fluid level and has dropped further, checked under car and found fluid leaking by near side rear wheel within the undertray, so I guess the pipe has corroded, has anyone else had this problem, didn't expect it on a nine year old car
