Hi
So I have had the wiring and everything burnt in my SL55 in rear boot because of this issue, managed to locate wiring from a breaker however just require the split charging ecu module. If anyone can help advise where I can find. I will be enquiring main dealers tomorrow and keep you posted
This is a common issue so would appreciate if anyone else has had a similar issue to be in contact
https://ibb.co/hZkLHk
