Mira Advance atl flex shower
Discussion in 'Classifieds - General for Sale' started by mercmanuk, Jan 6, 2010.
  1. mercmanuk
    mercmanuk Hardcore MB Enthusiast
    1,216
    Sep 29, 2003
    MIDDLETON MANCHESTER
    Car:
    C180 AVANTGARDE SE SPORT GONE AND MISSED LANDROVER FREELANDER 2 LET IT SNOW LET IT SNOW LET IT SNOW
    Brand new electric shower top of the range.
    information taken fron the mira website
    rrp £445
    will accept £200 ovno
    Mira Advance ATL Flex
    (9.0kW)Safe, precise, thermostatically controlled showering for total peace of mind. Inclusively designed for easy use by everyone. Advance ATL Flex is so safe it's earned a BEAB CARE mark - and so user friendly for blind and visually impaired users it's endorsed by the Royal Institute for the Blind. Flex brings extra flexibility with a rotary lever and colour contrasting panels plus extended fittings.
    Thermostatic temperature stability keeps showering safe for all the family
    Separate flow and temperature controls with push button start/stop and audible bleeps
    Adjustable Temperature Limit (ATL) - 8 different maximum temperature settings
    Four spray showerhead with rub clean rubber nozzles for easy cleaning
    New fittings: Smooth extra long slide bar with easy glide operation, close to wall fitting, wall or corner mounting options, friction clamp bracket means easy one handed operation, easily height adjustable, colour contrasting for easy navigation
    Large, colour contrasting rotary lever & buttons, raised areas to aid navigation, dominant on / off button, LED backlit flow and on/off buttons and audible click on temperature lever
    Colour contrasting panel to aid navigation
    Best in class limescale resistance
    New 'softened form' aesthetics
    Delayed shutdown turns off the shower gradually, flushing hot water from the tank for safer showering for the next user and reduced limescale
    Available in:
    White/ChromeRRP £451.20 (1.1643.005)
  2. OP
    OP
    mercmanuk
    1,216
    Sep 29, 2003
    Car:
    no offeres on this top of the range shower,thought it might have gone straight away with this cold weather
    if buyer needs cable,pipe, fittings etc this can be sorted
    offeres
Share This Page
