Right found the problem with my drivers window turned out to be a faulty relay after swapping relay to passenger side and the problem followed so went to the scrappy and picked up a relay put in the where the passenger relay goes and there was a big flash and a short faulty relay so took the drivers out and put it into passenger to test everything and the passenger window and both rear windows aren't working put the good relay back in drivers window and that works fine checked fuses and both ok so dont know where to turn next has anybody else had tgis problem grrrr
