dan f
- Nov 14, 2006
- AMG GLE63S
Hi All.
I have a bit of a poser for you.
I have a 2007 W164 ML. Just two days ago the front left (N/S) set of three parking sensors stopped registering any objects.
The system 'boots' as expected, all the LEDs light up upon starting ignition, front and back, but after that nothing is registered on the N/S Front corner, however the middle yellow LEDs are lit as normal.
The O/S F and the entire rear is fine and operates as expected.
I have long suspected that the N/S F hasn't been as sensitive as the opposite side (thinking one or more may be faulty) and it would appear the sensors have now given up.
Funny thing is the system knows all the sensors are there and says they are all fine.
This leads me to think the controller is fine and the sensors themselves have gone but not completely died.
I have been told that if a sensor goes the whole system should stop working, however when we first had the car, the N/S R sensor wasn't working but the rest were working fine.
Replaced the sensor and all was good. Which is why I hope this will be as 'simple'.
Does anyone have any experience of this and can anyone verify what the dealer tech said when he said that it could be the controller as it can go dicky in this manner.
Call me daft but I find it illogical that a single IC in the controller would not be able to operate one quadrant but it can the other three.
To me if the controller was faulty they system would register a fault at a single point, i.e. the controller... surely?
Willing to be put right on that however.
I look forward to any pearls of wisdom from peeps.
Cheers,
Dan.
Cheers,
Dan.
