Hi all looking for some help my ml has started making a whooshing noise recently when revving then stops when you get to 2500revs it quiets down,have read that it might be a split hose have checked as best i can couldnt find anything was told it could be the intercooler pipe choked with gunk took it off and it was so cleaned it as best that i could but no difference , what i did notice is the round sensor on the left hand side when you open the bonnet up if you take one of the rubber hoses off that go into the small filter beside it vacum hoses the noise stops ,there is no loss of power , the kick down still works fine and the turbo seems to be kicking in around 3000revs as normal it just had an oil and filter change about 2 weeks before this started dont know if that has anything to do with it but better to let you know , any thoughts and help much appreciated ,thanks.
