Ml320 Elecric Seat Not Working
Discussion in 'Electronics' started by madbonky, Jan 20, 2008.
  1. madbonky
    madbonky Member
    59
    Oct 3, 2006
    Heathrow
    Car:
    R129 300SL, ML 320, C240, CLK 500 CAB, W203 ESTATE
    Hello all,
    I have a 2000 model ML320. The passenger electric seat was working fine but has now stopped, i have swapped the switch onto the drivers side and the switch works fine on that seat. I looked at the fuse/relay box under the bonnet but cannot see a listing for a electric seat under either fuses or relays, does anyone know if there is another location for realys/fuses or even what could of caused the seat to stop working?
    Jay
  2. 666mcnally
    666mcnally Hardcore MB Enthusiast
    100
    Dec 16, 2007
    Nass Co Kildare Ireland
    Car:
    cl500,BMW525
    hi i have a cl500 and its behind the drivers seet and under the back seet look for a cover and it will pull off they are in there on mine
  3. richard
    richard Authorised Forum Sponsor Authorised Forum Sponsor
    5,344
    Jun 10, 2002
    Berkshire, UK
    Car:
    MY04 SL55, MY17 GLC250d AMG Sport
    I had this (although I didnt swop the seat switch over) on my 02 ML - all that had happened is that the power connector for the seat had come undone. As it was coming loose the passenger door mirror sometimes went to the wrong position with the memories. Basically the seat cable had got pulled at by my small childrens feet.
    As you've taken the switch out, i'm sure you'd have noticed that - but I thought i'd post it for others in case it happens to them
    R
  4. hash
    hash Hardcore MB Enthusiast
    237
    Jan 5, 2003
    oxford
    Car:
    Audi A8 08 with lots of toys & volvo XC90
    this was a common fault on w163, the clip breaks on the seat ecu and has to be cable tied back on or new ecu
    cheers
    hash
  5. OP
    OP
    madbonky
    madbonky Member
    59
    Oct 3, 2006
    Heathrow
    Car:
    thanks chaps, i will have a good look at the cables and ecu
  6. OP
    OP
    madbonky
    madbonky Member
    59
    Oct 3, 2006
    Heathrow
    Car:
    Ml Electric Seat Not Working!
    Well it is now! Just a loose cable under the seat, plugged it back in and hey presto, working seat. Thanks to everyone who replied to my original post.
  7. karateboy
    karateboy New Member
    1
    May 5, 2014
    clevedon ,somerset
    Car:
    mercedes mi320
    hi front driver seatwont move foward ,backward but will move up and down can any one help thanks karateboy
  8. MOZ
    MOZ Hardcore MB Enthusiast
    147
    Sep 3, 2014
    Knaresborough,North Yorks
    Car:
    W163 ML270 Inspiration, Leon Cupra TDI
    Resurrecting a really old thread, but just wanted to say, I have just had the same problem on my ML270 w163. Drivers seat was totally inoperable today ( it has been a bit iffy on the seat positioning switches for about a month - sometimes going backwards when it should have been forwards etc) but today - completely dead.
    I did a search and found this old thread, had a look under my drivers seat at the back accessing from the rear footwell, and as mentioned above a little black connector ( 8 way I think?) was hanging loose. Pushed it back into the module under the seat and hey presto all working perfectly again.
    I suspect it was dislodged a month ago when the car was valleted ( hence the strange behaviour ? It did start playing up straight after the valleting ( I thought it might have been some water in the electrics from the carpet wash) but was clearly this connector coming loose, and must have finally come out the last time the seat was moved back.
    Hope this helps someone else.
    All the best.
    Moz
Share This Page
