BallouBear
- Feb 22, 2016
- ML320 (W164)
I got a warning stating that my off-side rear indicator had a malfunction.
Checked the bulb, all ok. I cleaned up the bulb holder, tried again and it worked, however the near side indicator was now not working.
Checked the near side bulb, all ok. Cleaned the holder and still not working.
I swapped the holder and bulb with the off side but the problem stayed with the near side.
I also noticed some water directly below the near side light cluster.
I guess that the gasket is worn on the lens/light cluster?
I have dried it all out, but still the indicator will not blink. All other bulbs on the near side cluster are working ok.
Does anyone have any ideas what I could look at next to get it working again?
